1991 toyota 22re lower efi manifold question
Ok so today we were taking the evi off to change my head gasket buit noticed that their was tinny little puddles of oil in the bottom of the manifold. Can that be from the head gasket or something else bad plz help.
Blow by caused by the rings not sealing like they use to. Check your cylinders when you get the head off. Idealy you would want to do a leak down test, but you need the head on to do that...
mine he the same thing and rite where intake tube meet intake it has some oil spots , im thinkin mine is from the front hose on valve cover though or bad pcv valve
zd92655
03-06-2022 12:58 PM
Aleeex_u
06-05-2016 06:52 PM
