1986 Toyota Hilux coolant/anti-freeze
Does anybody know what coolant/anti-freeze my truck is supposed to take it is engine code 2L LN65. I can’t find anything and I don’t have the owners manual to check. Any help is greatly appreciated. Thank you
The following 4 users liked this post by millball:
YT Community Team
I think the Toyota Red coolant has all been swapped over to the Super long life pink coolant.
I've gotten Aisin pink coolant from Summitracing.com at a good price.
Back when I did my 3.4 swap I was told I HAD to use the Toyota red coolant or the world would end. At the time, the specs said it would not protect brass or copper and my truck still has a copper/brass radiator, heater core and T-stat so I have been using the universal green coolant for about 12 years.
Does the new super long life pink stuff protect the older trucks? It gets confusing with the HOAT and OET and whatever else they have now. It seems some will attack some gasket material so I have just been sticking with the old school stuff for my old school truck.
The following users liked this post:
JoeS (07-25-2023)
YT Community Team
Toyota always hyped their products over aftermarket vendors, so it wasn’t always easy to discern science from marketing.
what did get my attention was when engineers at the nearby Delco and Raytheon complexes were buying the Toyota coolant to put in they’re domestic vehicles, citing the formula as superior.
It certainly was easier to get a proper looking coolant flush on a Toyota that already had red coolant in the system by using new red during the exchange. If you’ve ever added green coolant to a system that has any residual red you’ll know what I’m talking about. Not a good look.
I can say that in all my years with Toyotas, I’ve never had a rust issue using red/pink. But I always flush at the designated intervals.
Genuine Toyota Parts - Genuine Toyota Fluid 00272-1LLAC-01 Long Life Coolant - 1 Gallon
You need to mix it 50/50 with distilled water.
I've also read that if you do a full coolant swap you can move the pink stuff (no mix), but I've not validated this.
I think, although very rarely, that the "pink" stuff is just the "red" stuff, only pre-mixed with distilled water. Once you put the "red" stuff into your system, and mix it 50/50 with distilled water, it looks exactly like what comes out of the container of "pink" stuff. You can buy 1 container of the red, and mix it with water, or two bottles of pink, and just pour them in as-is.
I may be totally wrong about all this, though.
Don't forget to give your system a good "burp" before you drive it. Those air bubbles are sneaky, and like to hide in the system if you don't get them out.
Good luck!
Pat☺
Good luck!
Pat☺
A little Googling tells that the anti-corrosion packages in the Red and the Pink are Different.
With the Red protecting copper and brass somewhat better than the Pink does.
Pink being preferred for alumunum radiators.
old87yota (07-28-2023)
YT Community Team
Well, some online dealers shows the red being available, while others have it "no longer for sale". So I dunno.
JoeS (07-30-2023)
PatchworkPatty
12-05-2018 08:28 AM
Vantucky
02-24-2011 04:58 AM
mmcpeck
05-01-2010 01:48 PM
Ksane
06-30-2007 05:20 PM
