parking lights come on by themselves
Old 11-29-2018, 09:44 AM
fishdan's Avatar
On my '85 4X truck the parking lights have begun to come on by themselves. If I turn them on and then off again at the switch they go off, but come back on in a few minutes, but not immediately-front and rear. Have to remove the fuse to keep them off permanently. Anyone ever have this situation?
Thanks!
Old 11-29-2018, 01:12 PM
75w90mantraN's Avatar
Not me, but looks like a case of shorts somewhere on a hot wire in the circuit. Maybe trace from the parking light on the wiring towards the interior and look for any worn or exposed areas on the insulation in contact with live wiring...good luck
Old 11-29-2018, 06:03 PM
RAD4Runner's Avatar
Yup, short somewhere...
Tail light relay contacts shorting, or
Wire (Red-Blk in 1988 schem.) between tail light relay pin11 and switch shorting to ground, or
Combo switch contacts shorting.
1988 lights but probably same as 1985.
Old 11-29-2018, 08:31 PM
fishdan's Avatar
RAD4Runner,
Much, much thanks for this diagram. Will print out and take out with me.
Old 12-01-2018, 07:33 PM
fishdan's Avatar
For the record the problem was in the switch. I removed the plastic cowling around the steering column and blew out decades of crap with an air compressor. So far that has done the trick, but keeping my eye on it as looks like to replace the switch assembly requires pulling the steering wheel.
Cheers!
Old 12-01-2018, 07:57 PM
old87yota's Avatar
Thanks for posting what you found!
You can find quite a bit of dirt in these old trucks, even the clean ones.
You may also have dirty switch contacts that an air compressor may not be able to remove. Post back here if the problem returns.
Old 12-01-2018, 08:03 PM
fishdan's Avatar
Jake,
Yea, there could still be dirt on the contacts. Will be watching for sure. Thinking about spraying something in there that might melt some of the grunge off, but that could be counterproductive.
Old 03-06-2024, 02:09 PM
874x4yoter's Avatar
Sorry to revive an old dead thread, but RAD, do you happen to have that diagram still? i am having this problem now and figured it was worth a shot to reach out. Cheers
Old 03-06-2024, 03:46 PM
RAD4Runner's Avatar
Pls try this.
paintthetown
13
01-26-2012 07:11 PM
6th Gear
04-04-2011 07:13 AM
newTOyotas
03-20-2011 04:09 PM
johnson1987
12-19-2009 05:33 PM
willdraps
10
03-18-2009 07:37 AM
Quick Reply: parking lights come on by themselves
