Birfield Problem
Got the third out too. Found out some interesting things too. The front is 5.29's with a locker! The question is, is the locker any good? If you put an axle shaft in it, it will turn the pinion and the other side. Its almost like its permanently engaged. I took some pics, maybe you guys will know if its engaged or not. Let me know what you think.
It definately is a ratchet style, like a lock right or something. Im just wondering if its in the right position and not locked. I'm hopefully trading it to jonny for his stock 4.10 diff in his 83, I just dont have the money to regear the rear right now.
#27
Its engaged, it only opens up when the right forces are applied to it. When driving with one, if you let off the gas or press in the clutch in a turn it will unlock. But if you hammer down on the throttle into a turn, it will remain locked.
#31
Yeah, we got a deal. How bout I trade the open 4.10 and the knuckle service seals/gaskets for it? When I get down there today we should make absolutely sure your rear is 4.10 and not 4.30 or somethin though.
#33
Better test... with the truck in neutral lift one of the rear tires in the air. Mark the pinion flange and the diff housing for a starting point, and chalk a vertical line on the tire. Now spin the tire 2 full revolutions while counting how many times the drive shaft turns. You will be able to tell if it was just over 4, 4.3, 4.5 ect.
#35
Yeah, he did that but only 1 revolution of the tire and got almost exactly 2 turns of the driveshaft. We just gotta do it again 2 revs cause of the open diff.
#36
Doh! Videos are good too, so it's always worth a shot to search youtube.
http://www.youtube.com/watch?v=duvs-xbKrW0
#37
Already got them out, but thanks for the video. Got one side rebuilt, all back together, would have had the passenger side done by now, BUT, the trunion bearings came out in pieces, and left the inners stuck on the end caps, so those are at the machine shop for removal, heading back out to finish cleaning parts and pull the 3rd out of the 83.
theking11863
03-19-2016 09:36 PM
