22re issue
22re issue
my truck has been a DREAM and an over 1k mile road tripper until yesterday the truck started right up with the usual little bit of smoke right away but started up real loud and idled unusually high at about 2k for a bit,
i parked at taco hell and after it refused to turn over, and giving it gas did nothing ,and when it does it missfires spudders and shudders real bad for about a minute
eventually it will idle fine and run okay
today i was driving engine bogged out when i tried to give it gas,
and when i gave it gas rpms dropped and truck nearly stalled but never did, if i released throttle and push the clutch the truck will idle normally, and rev seemingly normally, i some how "unbogged it" by revving the engine in neutral and giving it gas the truck seemed to fix it self for the time being and drive okay
i just replaced the spark plugs today it helped the startup a little, i dont know where to start, MAF? fuel pump? valve seals? rings? thanks
it will turn over, but not start. my mistake.
before the truck took a i would hear a weird humming coming from the front of the engine bay. i bet the fuel pump took a
Sounds like fuel pump to me as well.
I'd replace that and do a full tune-up on it (if it hasn't been done recently).
Mainly fuel filter, plugs and the usual cleanings (TB and such).
Fink
montanatruck
02-26-2017 07:07 AM
