timing spec
timing spec
Hey guys, I have an 81 or 82 motor in my 86 truck and was wondering what the timing is supposed to be set to on those years. Right now it's at 8* but seems a little fast. I've tried searching and can't find anything.
8*???? I thought that my FSM says 0*? I am certain the FSM says that actually. Are you guys disabling the vacuum advance to set the timing? or leaving it connected? I have been trying to get this engine to run better and perhaps I have the timing set wrong.
I can't remember where I saw it now but the specs were 8*, 5* and 0* for differernt years. I know that 86 and up are supposed to be at 0. I'll try to find it again because it had a breakdown for the different years. Yes, I disconnected lines from vac advance and plugged them when I set mine. 8* seems to be working good for me so far.
Found this:
75-82 is 8 degrees BTDC
83-84 is 5 degrees BTDC
85 22R and 22RE 0 degrees TDC
86-87 22R 0 TDC
22RE and RTE 5 degrees BTDC
http://forum.ih8mud.com/79-95-toyota...timing-22r.htm
Hope that helps some
86-87 22R 0 TDC
09-04-2015 09:27 AM
