Shackle Lift?
Shackle Lift?
I was researching on shackles some because i noticed that they could be a pretty cheap way to get lift. but i didnt find many people that used them? I read somewhere that they can mess up some angles and stuff but i was just looking for some opinions...pros and cons stuff. oh yeah and im referring to front and rear shackles to lift
Location: Houston (home), Atlanta (school), Cincinnati (work)
shackles can give you some decent lift and extra flex but you dont want to go TOO long, otherwise you need to worry about moving mounts, getting longer shocks etc etc. the problem with going longer is that youre allowing one end of the shock to move more (say the rear end) which COULD give you bad pinion angles, but thats a problem rarely heard of around here. i have longer shackles made out of steel stock and theyre fine.
thank you that helps alot...how long is to long tho? im just looking for like 2 inches of lift until i can get enough money to get a better lift, and i figured then i could just add the new lift to the shackle lift
I think that is right, i read it on 4crawler.com but does that mean i can use a 4 inch longer shackle to get the 2 inches of lift? or is that not reasonable and id just be able to get one inch out of a 2 inch longer shackle? thank you for your help and not flaming on me haha
I personally have a lifted rear shackle on my 88' 4Runner. I used this shackle to fix the "Saggy Butt Sydrome" that most have. I regret doing this because now my springs are flat. The only way to truely fix this is to get new springs or get an add-a-leaf.I recommend getting an add-a-leaf if you have a sagging problem. For lifting you could also use an add-a-leaf as well. They could make the ride stiffer. If I could do it all again I'd have done an add-a- leaf.
Lots of shackle lift info on my web page:
- http://www.4crawler.com/4x4/ForSale/Shackles.shtml#FAQ
I've run up to 3.5" longer shackles, that seems to be about the upper limit for length and decent handling. And yes, if a spring is sagging because it is overloaded, a longer shackle can give you some lift, but the spring will still be overloaded and continue to sag.
thank you for all the replies...sorry for not clarifying..i do have a 1987 toyota pickup but i just picked up an 83 that i would like to turn into my trail rig and just keep the other for a DD. IFS is just to expensive to make capable.
As far as longer shackles go? be careful just installing loner shackles in the front. The front axle will be rotated and mess with your caster angle. Getting 2? of lift with a shackle in the rear shouldn?t be too much of a problem. You will probably need longer shocks, it just depend on how much extra travel your current shocks have.
Shackles are relatively cheap, try them out. See how they work and if you like them. If they cause too many issues for you just drill the shackle plates for a shorter shackle.
also, it makes it easier to buy spares, it looks bling, which is enough for most...
Putting rear springs up front is probably a little above your altitude and air speed right now. Just stick to enjoying your truck while it is still close to stock. There is plenty of time to slide down the never ending vortex of modification and poverty...enjoy your truck while you can still drive it on the road...
Jon
thanks for all the info, im not planning on doing anything to my truck quite yet because i rushed into getting 33x12.50's for my IFS truck and later learned a 33x10.50 would have been a much better choice after i also purchased fender flares. So with the new 83 i picked up i am defanitly going to take my time and right now im just gathering all of the information i can
Longer spring in theory = more flex...sorta.
Jon
Jon
1uzRunner
63
11-10-2018 03:58 PM
