Power Steering Pump?
Hey Everyone!
a new problem with my truck... Really burnt smell, kind of sweet (not cooland), whining pully/ belt sound. I think my power steering pump is burning up. What do you guys think? Anything else I should think about?
I would think that maybe any one of the pulley bearings could be too blame, but I think I've heard that the power steering ones go more often than others. Didn't you have some issue with it before, too?
I don't know what it would smell like when they're burning up so I can't help there. If I ever get around to installing my power steering maybe I'll find out! I don't have my FSM on me but I wonder if there's a method for checking the pulley bearing other than just replacing it...
I did have some issues before... I had the horrible sound starting on really cold days... and I had a pully squeek for a while. I see what you are saying about any pully. The one thing I know for sure is that something is really heating some fluid. My truck STINKS like burnt fluid. The PS fluid seems to be the source, it has a strong burnt smell.I think the P.O. put the wrong fluid in the PS pump too, it doesn't look like ATF. I have been meaning to change it for a while. I also noticed that maxing out the steering alters the idle.
What is wierd to me though, the steering doesn't feel much different. I may have noticed in the last couple of months a mild wierdness on sharp turns, but it didn't stike me as being that unusual.
Thanks 83! I would be stoked on any info about the bearing.
Yeah I'll bet you're right about it being the power steering. I think the steering gearbox itself is fine with either ATF or GL5, but it's the pump for the power steering that needs ATF, so that could be it.
Anybody know: is the pulley bearing in contact with the ATF? Or is it it's own sealed-pre-lubricated unit? Could be your issue is the pump itself? Hopefully somebody who's had something similar happen will speak up.
Whoaa! Not the power steering pump, but the alternater!?
Whoaa! So I drive home ready to change the PS fluid and low and behold, my alternater was on FIRE! Funny thing is, my voltimeter showed a normal voltage the entire time... and the PS fluid is brown, not pink as it should be. I think I had two seperate issues here, I think I just had bad PS fluid for a while, not relating to this whole noise/ smell thing.
Good. Another good reason to carry a fire extinguisher. I have one...but that's because I stole it from my house so now my house doesn't have one. I need to do something about that.
development: leaking PS fluid could have burned up/ caught the Alternator on fire- may have two issue from 1 bad PS pump. Bummers- the alternator is a pita to change in my truck, I have this mount welded to my frame for a snow plow and it really has made this difficult
TURBOrunnerNM
07-22-2015 11:01 AM
jon.r
07-11-2015 03:34 PM
