Anyone running electric fuel pump on 22r
So I hooked up a napa 2-3.5 pump today to see if it would fix my fuel problem. I did not put it by the tank (I know, I know) I was hoping that it would start so I could move it onto the driveway so I would not have to lay in Bark to install it by the tank. So I was still not getting fuel. I am sure it is because it was not able to pull it that far. But I had done it before on other cars, maybe they had larger psi??? Anyways I was just curious if anyone had gotten theirs to pull like I was trying. Also, when you hooked yours up did you use the existing tube or run new hose?
Fuel
Yes I am running an electric pump with my Weber, but I had to install a fuel regulator to get it to run right. I have it set a 3# if I remember right.
Make sure you follow the Weber tuning instructions to the letter.
FS[SouthEast]: Mercury Villager Fan & DCC Fan Controller
coryc85
09-09-2015 06:24 AM
