81 22r electrical issues
I have recently gotten a an 81 4x4 which has had some issues. first it ran really rich, so I replaced the carb and sparkplugs which fixed that. Then we couldn't get it to run quite right wouldn't idle then would seem to run fine and then it would have a miss in it all the sudden then clear itself up again. Well voltage meter was reading 17 volts so we talked with a few people and were told to replace the external regulator, so we did and there was no difference. Then I replaced the battery, no difference, then I replaced the alternator no difference but I found in the paper work that there is a 6 wire and a 5 wire alternator which I needed the 5 wire and had the 6 on it. Now I don't know if it was over charging because of it being the wrong alternator which may have burnt the regulator up again, because the new 5 wire alternator isn't charging at all. Is there a way to test the alternator separate from the regulator or any other suggestions?
my truck ran the same with 5 or 6 wire alternator. the voltmeter inside my truck reads a bit over 12 most of the time as well. when i first got my truck it was having similar issues, ended up being a bad distributer.
FS[SouthEast]: Mercury Villager Fan & DCC Fan Controller
coryc85
09-09-2015 06:24 AM
v_man
07-23-2015 04:01 PM
Poncho0206
07-10-2015 06:21 PM
