22re swap from celica into '80 toy truck
so i picked up a 83 celica GTS. 22re. has anyone put one of these motors in a carbed truck? im wondering about the wiring and i know i have to change out the oil pan and pickup.
any info would be great, my crawler is sputtering out and now i have the solution!
feel free to call me if you would rather talk then type 707 703 2924 Don
Look up a 22re swap. Wiring-wise it should be the same to adding FI. I think you'll end up needing 6 wires, or something like that. Because its coming from a celica, I'd probably just run new wires, as opposed to keeping the celicas harness. Just less wires to worry with.
Hope this helps.
Hope this helps.
you should ask how much this guy wants for his V8:
http://jalopnik.com/339171/the-v8+po...ns-frostys-ass
or how about this V12:
http://jalopnik.com/339153/beautiful...8-hp-per-liter
The motor will bolt directly in with the expectation of the oil pan and pickup, as you already know. The only time consuming part will be removing the entire harness from the Celica and implementing it into the truck.
If you have the time and the $$$, do it right and rebuild the engine and have the fuel injectors (including the cold start injector) ultra sonically cleaned. Installing a new clutch and front seal on the trans would be wise.
