20r and 22r same timing chain ?
simple question do the 20r and the 22r use the same timing chain been lookin on ebay for just a replacement kit but they only have for the 20r and for the 22r with single timing chain my 22r is a 82' so dual row thanks, aloha
yes they are ...
20r chain will fit up to /84 . they even have steel back guides .
for those of you with a single chain , whom might want to convert , all you will need to replace are the guide bolts , and the oil pump gear .
one of the engines I built , /84 EFI duel row chain
So you don't need the timing cover off a 20R? I thought engnbldr told me I did, but that would really help if I didn't. I seem to remember that some 22R's were double row, so that would make sense.
22r and 20r timing covers are not the same. a 22r has heater by pass connection on the back of the cover on both sides, a 20r only has it on the passenger side, a 22r has en extra hole under the oil pump. I know because i found out the hard way.
09-04-2015 09:27 AM
