Spybot S&D Bad Check Sum - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Electronics > Computer Talk
Welcome to Yotatech!
Welcome to Yotatech,
Old 07-27-2004, 09:23 AM   #1 (permalink)
Glenn's Avatar
Hi
Every time I attempt to download the updates for Spybot Search & Destroy, it somes back with !!! bad check sum !!
What does it mean?
Any fix?
Thanx!
__________________
-Glenn-
Glenn is offline
Old 07-27-2004, 09:46 AM   #2 (permalink)
Morr's Avatar
Quote:
Originally Posted by Glenn
Hi
What does it mean?
Any fix?
Thanx!
No idea what it means, have got it before on corrupted zip files, I suspect this file is similarly corrupted.
BTW you're not alone, I had the same problem yesterday when trying to update spybot too, tried it on two different machines, but no go!
__________________
Maurice
1996 Toyota Hilux Surf SSR-G 3.0TD Auto
Fuelled by Vegetable oil
Mods: Interior switches and panels with blue LED's. Towbar. 4Runner load cover. Daystar 2.5" lift. 1/4" Wheel Spacers. 285/75/16 BFG A/T's
Waiting Mods: Recaro Seats to be fitted.
Hilux Surf FAQ at www.hiluxsurf.eu
Web hosting with 24/7 support and free domain names!
Morr is offline
Old 08-02-2004, 07:41 PM   #3 (permalink)
amusement's Avatar
A "bad check sum" means the file was corrupt either in transit or at the source.
Check sum is a method by checking the amount of bytes in a file. In the bytes don't match the expected value (check sum) then the file is corrupt.
Help it helps ... and it isn't your computer ... could be the download (network) or source file.
Cheers!
amusement is offline
Tags
bad, check, checksum, corrupt, corrupted, file, sd, source, spybot, sum, tools
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
how to check if a coil is bad? 85TurboRunner Off Topic Talk 6 12-04-2006 09:11 PM
Check Engine, SuperCharger & K&N sgirt 95.5-2004 Tacomas & 96-2002 4Runners 5 04-10-2006 05:17 AM
Best Ad/Spybot removing software 4x4Fink Computer Talk 16 11-16-2005 02:36 PM
Spybot Search & Destroy users Corey Off Topic Talk 4 03-07-2004 06:30 PM
Question to sum it all up Stump1883 95.5-2004 Tacomas & 96-2002 4Runners 1 09-20-2002 02:02 PM
2009 InternetBrands, Inc.
