New laptop screen hums...normal? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Electronics > Computer Talk
Welcome to Yotatech!
Welcome to Yotatech,
Old 12-26-2007, 10:31 AM   #1 (permalink)
BT17R's Avatar
My new Dell Inspiron 15" widescreen laptop screen (1680 X 1050 @ 60 Hz) gives off a faint hum at anything below max bright setting on either battery or A/C. The problem is that max bright shortens the 9-cell battery life from 4 hours on a usable brightness setting to 3. I have the bigger 135W auto/air adapter brick I'd rather not lug along.
Yesterday my niece brought her new nearly identically spec'd Dell Inspiron over. It has a 14" screen and doesn't hum under the same conditions.
I emailed Dell and they're ready to send a tech out today to replace the screen, something I'm not happy about having to do on a new unit still within the 21 day return policy.
I searched several boards and found that the hum is present on a random number of laptops like mine and a replacement may or may not cure the problem. Others just live with it. The computer performs normally otherwise.
One workaround is to use the Nvidia control panel to lower screen brightness. No hum then, but colors shift toward blue and look unnaturally cool, important since I use it for photo and video editing.
Should I push Dell for a replacement that may do the same, or is this something I'm overly sensitive to? I'd just as soon keep this one to save the hours of software installing and tweaking done already, but if it's an indicator of a future problem developing, I'll push for a replacement.
Otherwise, are there any other tweaks I'm missing that could help?
TIA...
__________________
'07 FJ Cruiser TRD SE 6M/T
BT17R is offline
Old 12-26-2007, 10:41 AM   #2 (permalink)
fastkevman's Avatar
I have a Gateway....no hum....hah hah!
But seriously I would push for a new laptop all together if its an option.
fastkevman is offline
Old 12-26-2007, 10:50 AM   #3 (permalink)
linuxrunner's Avatar
TIA...
There are some high voltage componants that run the monitor, usually just under the monitor hinges. On some laptops these componants can develop a very slight or very highpitched hum. By dimming the screen you change the amount of electricity that is running through them and this can also cause a hum or high pitched wine. It's up to you if you are interested in replacement, but i doubt the tech would replace the LCD panel (unless that is there policy) as it is most likely not the part causeing the noise.
It kind of depends on how loud it is. Is it something that you would have a hard time talking over? Or is it something that you can hear only when everything else is quite in the room?
If you still have a warentee than i say get it fixed... if not and it's not too loud i would start listening to music or just don't worry about battery life.
__________________
88 4runner 22re
Quote:
"Ditch that IFS because it is already crap and go for an SAS! (Single Axle Swap)"
linuxrunner is offline
Old 12-26-2007, 10:56 AM   #4 (permalink)
BT17R's Avatar
It's faint, only audible in a quiet room but it's at a pitch that bugs me and full bright is too bright. It's something I could get used to though, not bad but I'm focusing on it since it's within the return period.
The Dell tech just called and has a new screen with him ready to replace. I told him to call back tomorrow so I'll have time to read responses here.
Thanks so far...
__________________
BT17R is offline
Old 12-26-2007, 11:16 AM   #5 (permalink)
Heck, it's new and they are willing to replace the screen... I say go for it.
Plus you get a new clean screen out of it
If a replacement screen does not fix the hum, it's not your problem. Tell the techs that your laptop hums when the brightness it turned down and if they come and replace a part to fix it and it does not stop, it's up to them to contenue the troubleshooting process to fix it. They should not come replace the monitor and say, "oh well, we tried i guess you will just have to live with it" If it does not work don't let the tech leave without setting up another apointment to fix this thing.
__________________
88 4runner 22re
Old 12-26-2007, 11:53 AM   #6 (permalink)
89macrunner's Avatar
The thing that would be humming is the inverter for the backlight. That is not part of the screen and will most likely be inside of the laptop case, not in the screen/lid. have them replace your laptop and if that doesnt fix the problem maybe choose a different model.
hope this helps
__________________
Daily Driver: 2007 Windsor "The Hour" Fixed Gear 250 miles
Crouch Rocket 2005 Felt F80 1100mi (purchased new in Jan 2008)
2006 Mazda3 GT
2000 TRD Tacoma..Bought back and crushed
1988 4Runner SR5 V6 5 speed..sold
89macrunner is offline
Old 12-26-2007, 09:50 PM   #7 (permalink)
stormin94's Avatar
I don 't think the humming is normal. I have to hit my screen every once in a while because sometimes it turns yellow, and sometimes it fades very dark, but usually a good hit fixes it.
__________________
1994 Toyota 4Runner SR5 4X4
213,000 miles and counting
3.0 V6, 5 speed
10/15 MPG city/hwy(with 33's)
Current Mods
Headers, 2.5" Flowmaster custom exhaust, K&N FIPK
KC Daylighter 100 Watt lights
Ranchos x4, 2" Lift Downey coils
33-12.50 M/T's, 1" t-bar lift, 1" body lift
Tow pkg w/ lighthookups
Silverstar Headlights, Pioneer Deck w/XM
Brushguard
250Watt JLAudio 8" W3 Sub
Future Mods
12V Aux outlet-400/800peak inverter
roof basket/lights
Air locker
4.88 gears
H.O. Alternator
stormin94 is offline
Old 12-27-2007, 10:59 AM   #8 (permalink)
Staff
aviator's Avatar
New screen! new screen! just go and get the new screen! lol
why "get used to" something that is less then perfect?
You parted with a lot of bread for that gizmo man...
off topic I made an amazing soup with a turkey carcass the other day...
__________________
Silver 1994 Hilux Xtra cab 4x4 3.0
K&N cone filter, ported MAF, advanced timing, oversize exhaust, free flow cat, "rumble" muffler
custom covered SR5 seats, map lights, factory AC
tv4184 style black interior conversion started
mods to come... header,
custom centre console, stereo upgrade
tinted windows
Founding member 1972TLC fan club - Get well soon Mary
Toyota Hilux... Get in or Get out of the way.
aviator is offline
Old 12-27-2007, 11:47 AM   #9 (permalink)
BT17R's Avatar
I canceled the service call and asked for a new replacement laptop. They're building it now, should be here in a few days.
Mmm, turkey soup sounds delicious. I'm looking at the huge leftover ham bone (Chihuahuas are smaller) from Christmas and thinking of something similar, either a bean or pea soup.
But, we need pics of the soup kitchen!
__________________
BT17R is offline
Tags
hum, hums, laptop, screen
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Screen brightness Dell Inspiron 9300 laptop Corey Computer Talk 3 03-25-2007 03:32 AM
Rear window Won't go down - Motor Hums jaaydee 86-95 Trucks & 4Runners 5 03-12-2007 08:56 PM
How do you clean a laptop screen? Paul H. Computer Talk 11 12-18-2006 10:17 AM
White expanding Dell laptop screen of nothingness! Bob_98SR5 Computer Talk 5 12-07-2004 01:38 PM
Laptop screen Churnd Off Topic Talk 4 12-08-2003 02:58 PM
2009 InternetBrands, Inc.
