dyno Software? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Electronics > Computer Talk
Old 12-21-2005, 06:47 PM   #1 (permalink)
dyno Software?
Anyone know of any good dyno software besides desktop dyno that you can calculate hp and torque using different engine combos?
callmej75 is offline
Old 12-22-2005, 06:25 PM   #2 (permalink)
anyone??
Old 12-22-2005, 08:55 PM   #3 (permalink)
DudeBud's Avatar
Send a message via AIM to DudeBud Send a message via MSN to DudeBud
last i heard dtd is the only one. there is dyno 2003, but its the same as dtd but it has a few more features
__________________
Dan
84 4runner sr5 Ford 302
T-18 4spd yota t-case
yota front and rear both open
37X13.00 boggers
88 4runner 22re 5spd
DudeBud is offline
Old 12-22-2005, 11:20 PM   #4 (permalink)
Sponsoring Member
midiwall's Avatar
Hey man...
The math behind coming up with the number is pretty straight forward. Basically you're looking at how much "work" (HP) it takes to move a given weight a given distance. There're a bunch of sites on the 'net that will do it for you... Google Search
If you're looking for something a bit more "live", then check into some of the OBD II software/interfaces that're available. For example, I use the Auterra software with a Palm box that will do the math for me kinda' on-the-fly (it computes across the 1/4 mile).
__________________
~ Mark
'96 4Runner Limited S/C MI - 370cc injectors, Air! horns, Airaid MIT, ATS A-arms, 285/75/R16 BFG MTs, Bored TB, Brembo slotted, Cobra 75 WXST, Deckplate, Downey headers, Hayden cooler, IPT valve body, Level 10 torque convertor, Meanstreak exhaust, OME/OME rears, On-board PC (XM, Nav, WiFi, etc), Port 'n Polish, Remote Start, SAW fronts, Hilux console, SMT-5, Stubb's sliders, Supra MAF, TJM-17, 2.0" pulley, Viair 450c, Walbro 190, Weasy2k cams
midiwall is offline
Old 12-23-2005, 05:07 AM   #5 (permalink)
Quote:
Originally Posted by midiwall
Hey man...
Yeh I figure I could do the math but I'm taking the lazy way out and letting the software do it I guess what I am looking for is something like desktop dyno where I can put in different engine combos and see where everything matches up with hp and torque. Right now I have dyno 2000 but its a little outdated. I am going to use this on my next 2 yr project and stroking a 302 to a 331 and shooting for a goal of maybe 350-380hp and 385-400ft lbs torque. Then the 4Runner should come to life with maybe an AOD behind it. But this is all preplanning stages...something to get exact numbers for when I do decide to start buying things and getting machine work done.
Old 12-23-2005, 09:32 AM   #6 (permalink)
BlwnTuRD's Avatar
I use Car Tester, it lets you calculate many different things. Plus it has hundreds of vehicles in it already so it has some of the lesser known attributes put in for you; like weight distribution and such.
BlwnTuRD is offline
Old 12-23-2005, 09:35 AM   #7 (permalink)
Quote:
Where could I find this at? Whats the cost too..
Old 12-23-2005, 10:11 PM   #8 (permalink)
DudeBud's Avatar
Quote:
its easy to change a 302 into a 331 or what ever. frist you figure out what bore and stroke the kit has input it in and you shoule come up with whatever cubes the kit is going to make then from there figure your cam and head cfm out. here is one that i through together while looking through a summit book
__________________
Dan
37X13.00 boggers
DudeBud is offline
Old 12-23-2005, 10:41 PM   #9 (permalink)
BlwnTuRD's Avatar
CarTest2000
Here you go
BlwnTuRD is offline
Old 12-24-2005, 05:59 AM   #10 (permalink)
Quote:
Originally Posted by DudeBud
its easy to change a 302 into a 331 or what ever. frist you figure out what bore and stroke the kit has input it in and you shoule come up with whatever cubes the kit is going to make then from there figure your cam and head cfm out. here is one that i throught together while looking through a summit book
I think ya forgot to attach the kit
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
dyno...tune? ornery 95.5-2004 Tacomas & 96-2002 4Runners 10 11-17-2006 10:56 PM
How much for a dyno run? GREEN4SKIN'R 95.5-2004 Tacomas & 96-2002 4Runners 15 06-08-2006 11:12 PM
Dyno is in! Weasy2k 95.5-2004 Tacomas & 96-2002 4Runners 14 12-03-2003 09:04 PM
New dyno #'s Zubaltec 95.5-2004 Tacomas & 96-2002 4Runners 18 05-15-2003 11:57 PM
To DYNO or Not to DYNO??? HALMAN 95.5-2004 Tacomas & 96-2002 4Runners 1 06-24-2002 07:01 AM
2009 InternetBrands, Inc.
