Do power supplies just crap out?
I'm trying to diagnose a problem with my PC. The power supply had been making some noise occassionally after I turn on my PC. Now my PC won't turn on. I push the power button, it starts to power up, you hear the hard drive spooling, and then it shuts down.
I know it's difficult to diagnose a computer problem via the Internet, but maybe some of you can direct me where to check.
I bought a new power supply this morning and will hook it up tonight. If this doesn't solve my problems, what do you suggest I do next? Other then some occassional noise, I believe coming from the power supply, no other recent issues.
I have a P4, 2.4 gig processor, XP Pro, 512 mb ram, 2 internal IDE HDs, and a 128 meg graphics card. Any help is appreciated.
**EDIT**
I forgot to mention my PC stays on 24/7.
I don't believe the noise is from the HDs. The noise, mor elike a vibration, would stop when I put my hands around the back of the PC where the power supply is located.
**EDIT**
yea power supplies will crap out occasionaly. If its not the power supply it could be the hard drive? I dont think that would cause the computer to shut off though. if your hardrive begins to vibrate a lot, make noise and you hear a scratching souund, back everything up asap. More than likely its just a PS
Won't you know it, I picked up the wrong power supply.
I went to connect the PS to the motherboard and hit my first roadblock. My MB accepts a 20-pin PS connector, the one I bought (unknown to me until I tried to connect it) has a 24-pin connector. Unless there is some sort of adapter, back to Micro Center I go tonight.
Thanks for all the help. Hopefully a new PS will solve my problems. If not, I post here again.
