Computer Microphone
Computer Microphone
For some reason I can not get my microphone to work on my pc. I want to use it for gaming. I have installed new drivers, tried old ones. Used xp harware test selected the microphone have the volumes up, tried the mic boost. I can not get it to record on the record program or to work in any application that uses a mic. When i do the hardware test the volume bar is "pegged" and the slider moves down to zero and doesnt respond at all. Windows says there is nothing wrong with the hardware or drivers. The mic is new, and works on other pc's
:cry:
:cry:
Originally Posted by jimabena74
sure the card supports it?
Not sure of your software, but also check to see if you have a control panel like I do for my Creative Audigy 2 ZS.
Look at the far right, it should be set to mic.
Whenever I use my TV tuner card to record a show, it reverts it back to analog mix line in as seen in the picture, and it disables my mic and no one can hear me then in TeamSpeak.
I have to fire up the mixer here and change the setting back to mic.
Originally Posted by phorunninduke
Looks like the Mic imput jack has just gone bad. Need a new sound card to fix it.
Originally Posted by tulsa_97SR5
i've had mic's go bad, esp. cheap ones before. Anyway you can borrow one & test that?
I had gotten an email responce from realtek customer support and we desided it was bad. And since my mobo is otherwise spectacular I went ahead and purchesed a Creative Audigy 2 like corey has. Now I wish I had nice speakers to play things through..... Too bad I like to game with head phones on
i kinda had the same problem. I thought my soundcard went down the pooper. I ended up uninstalling it and then re-installing it and now it works great! glad you found a solution to your problem!
What games do you play?
Cool, you got the ZS 2 version right?
What I like about it too is you can go to Creatives website and do auto update on the software for it.
It is one of the best gaming cards out now, but they also just released the new Audigy 4 line (Creative X-Fi).
What is better with the Audigy 4 line is better headphone support.
I have been all about Day of Defeat source lately... I probably log the most hours playing counterstrike. Play some Battle field and Americas Army, but only every so often because I get tired of them a little more easily for some reason.
kawazx636
10-06-2021 03:03 PM
some drunk guy
08-03-2021 06:09 PM
