| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Trying to Trouble Shoot CB Issue???
#2 (permalink) |
1)replace the in line fuse with a 5 amp.
2)run a second ground back to the battery if neither of those work than take it to your loacl CB shop and have them check it out
__________________
1988 4x4 Pickup ISR/Battery-Intake Swap/216"c" Cam/ EGR removal/ |
#3 (permalink) |
I would check the fuse, but I wouldn't put a bigger fuse in. That could make something in the CB short before the fuse, negating the whole point of the fuse. Anyways, check the fuse and then trace all the wires.
__________________
Obama is an acronym. OBAMA = One Big Ass Mistake, America |
#4 (permalink) |
I should have mentioned...I did check the fuse and it looks fine
#5 (permalink) |
Did you check to see that there is power the the hot side of the fuse? You can do this with a test light or a multimeter.
Did your unit get pulled on recently? Maybe a connection in either end was compromised by getting over extended? I have the same unit and Love it! Good Luck!
__________________
'85 Standard Cab 4.5" HD SuperLift Custom Winch bumper 33x12.50 Mud Rovers Lincoln Locked in the rear; running 5.29s DD's: '87 XJ and '91 Suzuki DR650s Wheel Responsibly, Don't screw it up for the rest of Us. . . ---------------------------------------------------- "Obama is an acronym. OBAMA = One Big Ass Mistake, America" - Thanks for the Quote Hayes |
#6 (permalink) |
That's a good though on the test light.
but nothing has been pulled or over streched since its been installed. I'm going to give cobra a call this week since its still under warrenty. Thanks for the input |
#7 (permalink) |
if you have power going into the connector in the back (and providing a solid ground as well) then your problem lies inside the radio
#8 (permalink) |
Double check the ground, it needs as good of a connection as the hot
__________________
www.stockardmaintenancesolution.com Leave the trail a cleaner place than it was before you got there |
#9 (permalink) |
Also check your coax, If it has a raw spot it can fry a cb. Have you ever done a SWR check before it went out?
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Empty Campus=Good photo shoot, trouble with cops | MillerPKA | 95.5-2004 Tacomas & 96-2002 4Runners | 18 | 05-25-2007 08:27 AM |
| Shoot. | Mister Willie | Off Topic Talk | 15 | 05-20-2007 04:38 PM |
| TV Shoot needs Tacomas | Off Rd Producer | Off Topic Talk | 3 | 10-05-2006 04:55 PM |
| I am about to shoot myself | ColImport | 95.5-2004 Tacomas & 96-2002 4Runners | 15 | 12-30-2004 02:55 PM |
| shoot me... I need some help. | OneTrickToy | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 11-09-2004 12:27 PM |
