CB antennas
Going shopping on the weekend then.
Thanks for the tips!
That's where I wanted to go also but I have a camper top that I put on for camping and winter wheeling. Do me a favor and post a write up with pictures when you do the install. I'll do the same when I drill the hole and mount mine on top of the cab.
yes definatly ground to frame and bat. 102" is my personal choise, next to a mag. mount on the roof. but i had a problem with theives so thats why i no longer have a k40.....
good little radio.
#25
if you have an swr meter, tune the antenna yourself instead of paying somebody to do it for you. if not, buy a cheap swr meter (for the price you'd pay somebody to do it for you anyway) and do it yourself. that way if you need to move your rig to another vehicle, you can tune the antenna again right away.
#27
Hmm, after quite a bit of surfing, I came across this article:
http://wilsonantenna.com/tspu.htm
And this picture which seems very helpful, as it directly addresses pickup trucks.
#28
Okay, I forgot about this thread. I was reading a few of your posts about the dual antennas.
Anywho, I bought a mirror mount kit with 3' dual antennas and it came with a cable that splits in two right at the back of the cb with a "single" wire running out to each antenna. (I went to radio shack after I bought these and found a set of 4' antennas for $7 a piece, so the 4' is what will be on there) I heard somewhere that the minimum distance apart that they should be is about 4', so I am mounting them on the two far sides of the front bumper, which should be just over 4'.
If it does happen to be the wrong configuration, will it fry my cb? If not as long as it works for trails and the highway I should be fine.
EDIT: Followed the link that someone posted for the wilson antennas and that answered my question. I'll be fine with the same preformance as a single, I just like the look of duals. So "I wanna be cool"...Sweet...
#29
zombie_barbarossa
10-02-2015 10:54 PM
tazman1972
11
09-28-2015 10:32 PM
Ilovemountains
09-15-2015 04:17 AM
