YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Electronics > Vehicle Audio & Home Entertainment
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 05-19-2008, 12:57 PM   #1 (permalink)
chilly_bill's Avatar
Stereo mounting bracket? Help!
'91 pickup. The head unit in my truck is an aftermarket unit. I'm replacing it (it's b.. b... broken). The old one was hack job'd in. Are there brackets to hold the head unit in place? I had a '97 Corolla with shaped sheet metal brackets that bolted in to the head unit and then in to the center console, it worked great. How does this truck one work? Help!!
Thanks.
chilly_bill is offline
Sponsored Links
To remove this ad, register today!
Old 05-20-2008, 04:42 AM   #2 (permalink)
I'm not positive, but it should. That's the only way that it could be kept securely in place.
Clemsonfan15 is offline
Old 05-20-2008, 04:57 AM   #3 (permalink)
Elton's Avatar
Send a message via AIM to Elton Send a message via MSN to Elton
look at step 16 those are the brackets
http://www.installdr.com/InstallDocs...PDF/869017.pdf
__________________
My Truck 98 4runner SR5 3.4L 5spd 4x4 E-Locker Mods
Mom 07 Tundra d-cab limited 5.7L 4x4 auto
mom 92 pickup SR5 X-cab 3.0L 5spd 4x4
Papa 89 Pickup SR5 X-cab 4x4 3.0L 5spd/98 4runner SR5 4x4 auto 3.4L
R.I.P 91 4runner SR5 4x4 3.0L 5spd Totaled 5/13/06 My Wreck
Elton is offline
Old 05-21-2008, 12:52 PM   #4 (permalink)
Hmm. that looks identical to my old Corolla. It's different than my truck though. Any other ideas? My truck only has single DIN.
Old 05-26-2008, 09:40 AM   #5 (permalink)
Send a message via AIM to yotakid825 Send a message via Yahoo to yotakid825
I had to buy the brackets. A good install kit would be the way to go
yotakid825 is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
noob-mounting bracket/water pump/t-belt/e-fan install ryoooota 88 86-95 Trucks & 4Runners 1 04-02-2008 06:06 PM
Stereo bracket screw dimensions? eyw Vehicle Audio & Home Entertainment 0 02-12-2008 04:16 PM
Front Brake Line mounting bracket 85badger The Fab Shop 8 11-17-2006 08:28 PM
WTB ASAP! Throttle bracket / Kick Down Cable bracket. terrytcl Items Wanted 0 07-14-2006 09:47 AM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
