Vehicle Audio & Home Entertainment Discussions here pertain to vehicle stereo systems and home entertainment systems
Stealth sub enclosure
Old 06-04-2011, 01:49 PM
slorunna's Avatar
I was sick of my sub boxes stealing my precious cargo area, so I decided to venture into the rear panel. I found alot of space .
So the build began...
Trimmed inner panel (green) and extended drain tube (red)
Glued and screwed mounting plate for subs
Backfilled cavity w/ Great Stuff
Reinstalled panel
Applied a coat of fiberglass mat around the perimeter of mounting plate
Installed subs to test for rattles and sound quality.
Alot of air moving back there and the factory clips simply were not going to work. Replaced the panel clips (green) with 10mm bolts (red)
Pneumatically sanded w/60grit and applied 2nd layer of glass w/cloth.
Pneumatically sanded w/80grit, bondo'd, Pneumatically sanded w/120grit, initial coat of filler primer.
Hand Sanded w/220 grit.
Heavy coverage w/ filler primer.
Hand sanded w/400 grit.
Color Primed
Subs installed w/ grilles.
I will be bedlining the entire cargo area and replacing the carpet w/vinyl so this project will be revisited once I get some decent weather.
Old 06-04-2011, 02:08 PM
muddpigg's Avatar
There's a guy on here that did the same thing. Been a few years since I've seen the post though. Perhad some one will post a link. It's an awesome place to mount though.
Old 06-05-2011, 06:51 AM
Adk_Yota's Avatar
looks great!
Old 06-06-2011, 05:58 AM
aviator's Avatar
Looks really clean...
idea... If you spray some rubberized asphalt undercoating on the backside of the body skin you will kill a lot of the vibration and "boom-y-ness"... Dynamat sells the same product as "Dynaspray" for about $20 a can but you can pick up good quality rubberized underspray for about $5 a can so.... I used it on my doors and it really makes a difference... do 2-3 light coats not 1 heavy coat for best results...
Old 06-06-2011, 08:29 AM
slorunna's Avatar
Originally Posted by Adk_Yota
looks great!
Thanks man. It sounds great too. I'll get a video up soon.
Yea, that stuff is awesome. I have used it on other boxes I have made. suprisingly enough though it isn't too boomy with the polyfill back there, but I like that idea and might do it when I pull the panels to bedline them.
Old 06-25-2011, 08:15 PM
yotaman4runner4ever's Avatar
where did you get the gards over the subs
Old 06-25-2011, 08:28 PM
slorunna's Avatar
Sonicelectronix.com for like $10 a piece
justdifferentials
Just Differentials
06-13-2022 07:40 PM
Cebby
36
08-20-2006 01:53 AM
Brad
12-09-2004 09:23 PM
s_wall98
20
03-08-2004 02:51 PM
rmfordham
12-25-2003 07:35 PM
Quick Reply: Stealth sub enclosure
