Extending subwoofer speaker wires---is it ok?
guys,
i got one of those q-logic boxes for cheap a few months back and now i am getting around to installing it. i will see if the quality of sound will be significantly less than my current sealed box and decide whether to keep it or not.
anyways, the current length of my speaker wire to my sealed box will not reach the rear passenger cargo area. thus, id like to know soldering and extending it will cause the sound quality to suck. i would hate to pull up the carpet again to rewire it. not that bad of a job but i'm feelin' lazy and pressed for time
bob
bob
I would say the sound quality wouldnt be as good. Now since you are soldering, it would be greater than someone who just connected the wires, but less than someone who re-ran wires.
I had the same dilema a while back and I was told to run new wires, so I did.
Hope this helps
Hope this helps
How much length are you talking about adding? What gauge is the wire now? Is this a run from an amp to a sub or a preamp to an amp? If it's from the amp to the speaker, how much power are we talking about?
In general, you'll be fine; it definitely won't cause the sound quality to "suck" though you would be able to measure a capacitance difference between a straight run and one with a joint in it. The difference will be in the picoFarad range, which will tend to act like a low pass filter with a VERY high cutoff point which is an okay thing for a sub.
Keep the joint clean (i.e., no a cold joints), use the same (or greater) gauge wire, and insulate the joint with heat shrink or a good _individual_ wrap of electrical tape.
I'd say no way would/could you hear a difference in sq considering the freq a subwoofer would play at especially since we are talking about a driver playing in a noisy truck, behind some seats, rattling everything it can .......
Originally Posted by ricky
The more connections made, the more power lost. Rerun the wire.
but you're on the right track if you found more wire, re-run it to make it look cleaner, and even better fold up a foot or two under the carpet in an area where there is space to allow for further changes later
bob
bob
Not sure if you did this yet, but lengthening the speaker wires won't matter for the sub. Also if you can help it try not to have too much slack in the wire. Folding it over under the carpet is a bad habit and can cause interference if you ever decided to go bigger. Just use what you need.
Originally Posted by NisAznMonk
Bob,
bob
primordialbeast117
12-19-2015 12:23 PM
kcaudill
10-10-2015 02:39 PM
kbpickens
10-02-2015 03:37 PM
Odin
09-26-2015 06:56 PM
Toys4parts
09-26-2015 01:56 PM
