Welding my gears?
Old 05-07-2014, 10:49 AM
Plymota's Avatar
Welding my gears?
So i recently picked up my new project. It's going to be a 4x4 rat rod and the frame/ axles are going to be Toyota. The rear axle is from a 1989 Toyota truck, and I have it all tore apart, but before I put it back together I was wondering how do I weld these gears to make it posi? I've torn apart other axles but this looks completely different to me. Pictures would be awesome too. thanks
Old 05-07-2014, 11:16 AM
JasonYota's Avatar
You weld the spider gears together and it makes a spool. Aka Lincoln locker. Google search welded spider gears for pics
Old 05-07-2014, 11:22 AM
HighLux's Avatar
its a hack move....
The following users liked this post:
old87yota (08-15-2019)
Old 05-07-2014, 01:46 PM
Stevesk88's Avatar
Do it!!! make a small plate and melt it on one side of the gears. Then let it cool and do the other side.
its a rat rod highlux...not a crawler or even a daily driver i bet. No need to spent money on a locker or even a spool...
Old 05-07-2014, 03:36 PM
HighLux's Avatar
Unsafe on the street. First good turn in the rain he takes out a bus full of nuns with kittens.
Old 05-07-2014, 05:04 PM
Stevesk88's Avatar
Unsafe if you have more than four squirrels in front of it and your dumb about when to gas through a turn. I see nothing wrong with a welded rear if you know how to drive accordingly. It will eat tires and you will probably want to make sure you don't wheel hop that axle right out from under your rig. Don't ask how I know.
Old 05-07-2014, 05:25 PM
HighLux's Avatar
Ha ha. You get me. Its a great budget lock for a trail rig. I cant condone it for the street...as I wouldn't a spool either.
My problem is...you smoke a good rear end to do it. No going back. I think people should know that is a little skeet, and dangerous on road. I know lockers aren't cheap...are more difficult for the average guy to install.
But at least you can sell it, and someone will always snap it up...and they hold decent value for a part.
Old 05-07-2014, 06:26 PM
Robert m's Avatar
Old 05-07-2014, 06:28 PM
HighLux's Avatar
Originally Posted by Robert m
How would that go back in the carrier? LOL
Old 05-07-2014, 07:23 PM
Stevesk88's Avatar
That's no joke man...take that pic down. It's yotatech were one here! He might do it!
Old 05-07-2014, 11:05 PM
wyoming9's Avatar
Red face
Just keep plenty of rears on hand after awhile you will be really good at changing them.
I used to weld these all the time telling customers it was at there own risk. Now I just say no.
Old 05-08-2014, 08:01 AM
Stevesk88's Avatar
Above all....make sure we get some pics of this 4x4 rat.
Old 05-08-2014, 06:58 PM
Plymota's Avatar
I know you have to weld the spider gears together, but the reason I'm asking is because I don't know how I would get to them to weld hem? What is the thing around the spider gears? Can I take it off or what?
Old 05-08-2014, 08:17 PM
Yotard's Avatar
You need to research how to remove the carrier and then how to reset the carrier bearing preload and the backlash. The carrier comes out to get to the spider gears but you will just blow up your gears if your can't set bearing preload and backlash. Sounds to me like you are in over your head.
Old 05-08-2014, 09:37 PM
Stevesk88's Avatar
Leave it all together man. Drop a plate in the gears, or not doesn't matter. Weld. Cool. Weld otherside. Cool. Install. Drive responsibly if your using it on the road. Then proceed to do burn outs.
Old 05-08-2014, 10:46 PM
Fossilized
Staff
dropzone's Avatar
The OP has a V6 carrier...harder to weld the spider gears than a 4 cyl third
Old 05-09-2014, 12:19 AM
HighLux's Avatar
I wonder why people dont listen to sound advice and charge down the path of knuckleheadedness?
Old 05-09-2014, 04:34 AM
Yotard's Avatar
He has a V6 third member, see his pic, it is a stronger 2 piece carrier but there is no way to get to the spider gears to weld them without taking the carrier out and apart.
Sorry I just saw drop zone already answered that for me I was still on page 1
I had a spooled 67 Cj and it was horrible as a daily driver. my 89 suburban had a better turning radius than my jeep because of that spool. Get a lunch box. If you don't have the money, save up for it. You can't go back once that is welded.
Old 05-09-2014, 07:03 AM
Plymota's Avatar
Okay, so welding this will be the cheapest thing to do but probably not the most practical seeing as how this is going to get driven a lot. What about lockers for this axle? I know they are not cheap, but what is the most cost effective one?
Yotard, what do you mean by get a lunch box?
Old 05-09-2014, 07:35 AM
Yotard's Avatar
Lunchbox lockers describe a whole range of mechanical lockers that replace your spider gears. Since you have to remove your carrier to even weld the spider gears then you might as well install a locker because you will get better performance for the same amount of effort plus a little extra money. In a turn, spider gears allow your slower inside wheel to differentiate from the powered outside wheel that is spinning faster. In a turn, a mechanical lockers allow the outer wheel to ratchet faster than the powered inner wheel, but maintain spool like lockup if you apply power at any time...If you turn hard and hit the gas, it will still act like a spool and jump and chirp and bang but if you coast through turns it will behave more like an open diff except you will hear the ratcheting sound of the locker unlocking.
I have front and rear locked differentials in my truck I have Spartan lockers front and rear. I paid around 230 bucks for the rear Spartan locker and the cheapest I found it was on ebay with free shipping brand new. Look at gearinstalls for examples of how to install and an overview of the tools and practices on how to take the carrier out, reinstall and setting backlash and preload. Ken is a great guy and helped me out a lot.
Quick Reply: Welding my gears?
