ft. bumper hi-lift mount
I had my hi-lift on the top rack but it was hard to get to so I decided to fab up a ft. bumper mount. I didn't want one that just clamps to the stinger because it would not clear the headlights. I have a pin that goes thru the middle so I can lock it. It also takes a lot of weight off the one side of the rack,,,,, picture time
Thanks,,,, I made it high enough not to block the headlights. You can kinda see in the last pic where it sits a little above them. that is what I didn't like about the clamps that clamp on the stinger. It would have been right in the middle of the lights with the small hoop.,,,,,, edit to add pics of headlight clearance....
YA know I was getting ready to do something very similar but just wondering is your jack a 48 or 60 inch? I just kinda want an idea of what a 60" would look like width wide on the front vs. the 48"
Harley,,, it is a 48 extreme,,, it is almost the same width as the hood by looking at it,,,actually not quite as wide,,,, you could slide the clevis adapter down a little ways on the jack and it would make it a little shorter,,,,just measure your truck and see if a 60 would stick out,, I don't think it would,,,,,,,,, ,,,,,
37's when these are done,,, it is an auto but I'm running 5:71 gears and it pulls these(35's) great even in overdrive,,, thanks for the complements,,,,, ,,
Peevedkitten
11
08-31-2015 06:57 PM
priest16
15
08-06-2015 07:43 AM
MTLroadierunner
07-20-2015 03:07 PM
mengquis
07-13-2015 10:39 AM
