Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
4Hummer's Snorkel (Pic Heavy)
I've been Getting Email after email and PM after PM in regards to my Snorkel Build. My website is no longer online (Lack of time) So all my previous images are gone.
Heres my Updated snorkel Build: Snorkel Ala Cheap. Parts Needed: 2.5" Flexible Shop Vac Hose $19.95 Safari Snorkel Head $75.00 2.5" Inch Exhaust Pipe $Free 2.5" Plumbing Cap $1.00 2.5" Pluming Gasket $1.00 First off this is for a 22RE but I would image it's the same for any 4Runner. You will notice there is a wire loom that comes out right behind the air box ![]() You need to open this up in order to fit the Flexible Hose threw ![]() Heres a PIC of the Drilled out AirBox. The Hose beside is flexible 2.5" Shop Vac Hose. (this stretches out to 8 feet) I cut one end off, and fish mouthed the Other end so the Air Filter fits in the air box. Theres a metal rod Threw the opening to hold it in the air box ![]() Installed in the Air Box ![]() Back Side Sealed up ![]() The Blue Cap is just a PVC Plumbing Cap. I can remove it when Driving on the Road, and CAP it when off road so that I only breath threw the Snorkel Pipe Part 2 coming up in a minute |
| Sponsored Links |
#2 (permalink) |
Snorkel Parts
2.5" exhaust Pipe 3feet long 30Degree bend at top (Pipe was originally 4Feet long, this is required in order to bend it, and than cut off the top right at the bend. 2.5 Inch Plumbing gasket (The Snorkel head is 3" exhaust pipe 2.5" Gasket goes between the Head and pipe) ![]() Here is the Hole in the Fender (The grommet has since been replaced) The Brown Spooge is Rust Spray ![]() Heres a pic of the section you need to cut out of the Fender do the pipe can fit. (Old Cell phone pic sorry) ![]() Shop Vac Hose from Air Box Stuffed into Exhaust Pipe ![]() ![]() Last edited by 4Hummer : 04-04-2008 at 08:14 AM. |
#3 (permalink) |
Finished Product:
![]() ![]() ACTION SHOTS ![]() ![]() |
#4 (permalink) |
looks real good, the only thing i would have done is use the 3" pipe, it kind of looks a tad small. But still looks good, nice work.
__________________
97 4runner, 2.7 5speed 4wd, 4.556, 255/85/16 Maxxis Bighorns rear diff breather, 4 hella 500's driving, sliders, wilderness rack custom bumper arb locked rear toytec adjustables, ome 891's, bilstein 5125 manual hubs broken front and rear swaybars My Profile |
#5 (permalink) | |
Quote:
Plus when you bend 3" Pipe on a mandrel it kinks it pretty Bad. and looks ugly! Ill post pics of the 3" bent |
#6 (permalink) |
how come everybody puts the snorkel head on facing forward? It seems like it'd be smarter to put it on facing the back so when you hit the water it doesnt spray up into it
__________________
2000 4Runner Limited V6 Auto... 2wd =[[[ Sony GT510 head unit, Kenwood 1700 watt max mono amp, Two 12 inch Polk Subs in ported box, 3 farad capacitor, neons in front footwells Foglights on bottom of rear bumper Optima Yellowtop, Kc daylighters on front bumper Vortex muffler and Trueflow airfilter |
#7 (permalink) | ||
Looks Great!!
I always wondered about that myself.
__________________
Quote:
Quote:
93 Runner, 3vze, auto, 4.88 gears, 31" tires, mostly stock, 255k and counting DD: 94 runner, 3vze, geared 4.56, m/t, 31/10.5/15, only 200k on the clock Project: 91 p/u, 3vze, m/t, 2" body lift, 4.10 gears, 33's, 219k on the clock. It's becoming an addiction. |
#8 (permalink) |
I would think it goes forward to get more air... just my .02
__________________
'92 pickup, xtra cab, manual 3.0, 4x4, 31x10.5 |
#9 (permalink) |
You get alot more cool air flowing with it pointed forward.
__________________
1986 4runner 31" mt's aftermarket shackles Custom front bumper/winch Light bar/auxilary lighting Rear Detroit future mods: 33's maybe 35's, 5.29's, Rear bumper with tire/jerry can,highlift mounts, sliders. Conquer with the IFS until I can't conquer anymore and then do an SAS. |
#10 (permalink) |
thats the only advantage i see but it cant be that great, its not like your making a supercharger out of tubing. and if it is then why not twist it around when your about to go offroading
__________________
#11 (permalink) | |
Hey Great Job
I second the guy that wants to do this with 3" just a quick correction Quote:
edit heres a quick ebay link to some mandrel bent U's http://cgi.ebay.com/ebaymotors/Exhau...mZ120215392998 notice no crushing.
__________________
~Brian 89 Ex-Cab 3.4 Conv. T100 Tranny Yep i Changed it. Soon to be Supercharged. 90 4runner 3.0 Auto (Wifes Toy) I sold the HEEP I Havent finished my writeup but till i do heres a link to Mt_Goats write up http://www.yotatech.com/f116/3-4-swap-started-82145/ between him and i and a few others on here we should beable to answer most questions. Last edited by thefallman : 04-04-2008 at 05:43 PM. |
#12 (permalink) |
hey nice build.
i was jw what you did to seal your distributor and other electrical crap? cuz thats my prob is water in the distrib. thanks! |
#13 (permalink) |
looks great, also like the new paint!
__________________
305k MILES! 97 4Runner Khumo Road Venture MT's 285 75 16's LC wheels,Desert Dune,moonroof,safari rack,kc daylighters,3.4 Ltr. 5 spd,410s detroit ez locker, OME 891's, KYB shocks3 - 3.25 lift, Tokico,Taco springs,3 in lift in front Rev Tek spacers/top out 4Crawler diff drop, 1 in BL, 4 Runner altimeter, 2.5 in Flowmaster,high flow cat, mandrel steel air intake conical K & N. MSD DIS4,CB with 7 channel wave/weather report,4 foot firestick,Pioneer CD,30 gig IPOD. www.sfaboston.com |
#14 (permalink) |
the snorkel heads are designed to shed any water that would get splashed up, making rain etc no problem with it facing forward. the effects of more cold air outweigh the "negatives" of water splashing
__________________
-David 2000 Taco TRD Access Cab v6 | 5spd | 33" BFG A/Ts | 33" PC Mud Terrains | OME 882's | Bilstein HD struts front | Rancho shocks rear | Chevy 63" leaf spring swap | Custom sliders | Custom front bumper |3" BL | U-Bolt flip | Flowmaster exhaust | Kenwood Speakers | Grey Wire Mod | Aux. Reverse Lights | Deckplate Mod | Lots of lights Pictures |
#15 (permalink) |
Thanks. $50.00 Paint Job special. SOON it will be urban Camo
#16 (permalink) |
cherry,
nice article. |
#17 (permalink) | |
Hey Michael, you finally did it!
Quote:
Cheers, David
__________________
'94 Toyota 4Runner 3.0 Turbo Diesel Intercooler – Trail-Gear 4'' SAS front, Trail-Gear 5'' rear leaves swap, 35x12.5x15 M/T's and too many things more to write... |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Fillsrunner4 3.4cralwer -pic heavy! | fillsrunner4 | The Fab Shop | 437 | 10-15-2008 07:01 PM |
| Interior Revamp thread, pic heavy | 98horunnin | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 04-01-2008 12:56 PM |
| Another SAS into an 87 PU........BIG PIC HEAVY | bleakhorizon | Solid Axle Swaps, All Years | 2 | 03-16-2008 07:52 AM |
| Canadian run to Lingham Lake (pic heavy) | 91 4Runner | Trip-Trail Reports & Photos | 14 | 07-14-2006 07:42 AM |
| Very Cool Sidewalk Art (pic heavy) | msw0085 | Off Topic Talk | 8 | 04-15-2006 09:19 AM |
