1st gen truck frame cracked by steering (IFS)box, plating suggestions
I was looking at the front end to see if I was going to have tie rod clearance if I pushed my front axle forward an inch or so by redrilling the spring pad...
Looks like that will not be an issue but found something I always knew was a possibility:
I know the right way would be to pull the steering box and plate the frame..that is something I want to do but am wondering if something like this might work for a good temp fix(borrowed from pirate) so I could still drive the truck, just not wheel:
this is something I had meant to do for a few years...might have prevented the crack above..
i am thinking I will see if I can do something about this gap that I believe is from the factory.
GreenLion
06-07-2021 10:49 AM
voiddweller
19
05-02-2016 09:10 PM
