VSU_4runnin's Profile/build up... - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > YotaTech Community > Check Out My Truck (No one can answer you in this section) > 4Runners-3rd gen
Welcome to Yotatech!
Welcome to Yotatech,
Old 01-01-2009, 09:49 PM   #1 (permalink)
VSU_4runnin's Avatar
This shall be my profile to see and enjoy.... Per Forum Rules, Please NO COMMENTS
My rig 98 4runner SR5 4WD 2.5" lift, land cruiser rear springs, 33" BFG A/T Ko
The day aafter I bought it... all shined up
after a wknd of Camping
Before the lift
After
Tellico Falls
PER FORUM RULES NO COMMENTS!!! pm for details.questions
__________________
1998 Toyota 4Runner:
33" BFG A/T T/A: KO 2.5" Lift
CB Radio Brush Guard
Yakima roof rack
manikin head (Viola), and more to come!
Clicky For Picky
Buildup
GATTORA
KJ4HVQ Skywarn Ga 208
ΦΣK
DAMN PROUD!
VSU_4runnin is offline
Old 03-02-2009, 06:06 PM   #2 (permalink)
Well this week I got some special presents!!
After months of researching, and cursing UPS I finally got all my ham radio equipment..
I decided on a Yaesu FT-7800r VHF/UHF radio, with a Diamond sg7500a dual band antenna, and a Diamond K400s mount. I ordered from universal radio, they were very helpful, were able to reccomend things, and put up with all my questions.
(for some good information on various radios, getting cert.'d or general info see this thread)
The first thing was to make a filter to help cure alternator whine due to the A/C interference
Special thanks to toyospearo for this
(how to)
And Mounted using lots of gorilla glue, and mighty putty
Then I installed the Antenna and mount
It Folds!
Then I ran the coax into the cab, I went down one of the hood supports, then pulled it into the quarter panel, in through the door jamb, then through the plastic kick panels (or w/e theyre called, and then cut a small hole in the carpet to pull it through.
Then I mounted the radio to the floor with the supplied mount. I had to drill 2 pilot holes (and fight the insulation padding under the carpet) for the supplied self-tapping screws. Then I pulled the power cord through the carpet, behind the front dash then I drilled a hole through the firewall beind the brake pedal, and sealed it up with mighty puddy for strength, and silicone as an extra percaution, it was a pretty big hole so I could fit the inline fuses through. Then ran the positive to the filter, and Neg. to ground/battery ground.
Then I looked online for a remote mount kit for the radio, but they were all $40 and up so, I improvised. I ordered a Cat3 cable off ebay for $3 and used a mic. clip as the bracket attached to the faceplate. It was just the right thickness to jam into various places, and I had to bend it a little in a vice grip to get it to the correct angle. I drilled 2 holes and put 2 small nuts and bolts through the back pannel of the faceplate to attach the clip.
Then I pulled the Cat 3 cable (6 pin, 3 straight sets of 2) through the center console, took out the dash, it is much easier if you pull everything out, incl radio. and other stuff.
Then I drilled a hole through the air ducting and taped it up so I can keep all the AC I can, especially down here in South Georgia in the summer. Then pulled the end of the cord through the vent. This way if I take my faceplace out, I can just puch the wire back in the vent.
The Finished Product!
As always Pm me with questions!!
Thanks!
__________________
Yakima roof rack
Clicky For Picky
Buildup
GATTORA
ΦΣK
DAMN PROUD!
Tags
diamond, k400s
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Mokai's Profile mokai Tacomas 6 11-24-2008 07:18 PM
Texas_Ace Profile of my 2000 4runner limited 4x4 build-up Texas_Ace 4Runners-3rd gen 1 08-25-2007 04:10 PM
Jared's Profile Jared 4Runners-4th gen 5 03-11-2007 07:52 PM
Brandontrek's Profile brandontrek Trucks, 3rd gen-'89 to '95 0 11-10-2005 03:21 PM
2009 InternetBrands, Inc.
