Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
whats the downside in using driveshaft extensions
whats the difference of either getting the extensions or justing getting a more heavy duty driveshaft
| Sponsored Links |
#2 (permalink) |
Well, using an extension causes your DS to be shorter so, worst U-joint angle. Other than this I cannot see another.
David
__________________
'94 Toyota 4Runner 3.0 Turbo Diesel Intercooler – Trail-Gear 4'' SAS front, Trail-Gear 5'' rear leaves swap, 35x12.5x15 M/T's and too many things more to write... |
#3 (permalink) | |
Quote:
- http://www.4crawler.com/4x4/ForSale/...ftSpacer.shtml ![]() If the problem is that the slip yoke is not long enough (that is it can compress fully yet extends too far and separates), then the extension will not help, a longer slip yoke will be needed. As noted, the angle on the driveshaft will be slightly higher with the extension, but not by much. For example on a ~24" long front shaft at a 20 degree angle, a 1" extension would add perhaps 0.8 degrees to the angle. The angle change will depend on the length and angle of the shaft and length of spacer used.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs. r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad Gettin'Off 4WD Club Last edited by 4Crawler : 06-07-2008 at 09:08 AM. |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Bumpstops and Extensions | AZ4ME | Axles/Suspensions/Tires/Wheels | 7 | 02-08-2008 10:42 AM |
| Driveshaft Extensions | cubuff4runner | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 03-24-2005 08:17 AM |
| Pedal Extensions? | Eliyah | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 01-17-2005 08:13 AM |
| downside to car washes? | lee | 95.5-2004 Tacomas & 96-2002 4Runners | 26 | 12-28-2003 04:37 PM |
