What kind of locker?
Old Nov 9, 2004 | 01:21 PM
CrAshBy's Avatar
What locker should I get for my 2000 Taco v6? I want some selectable so I'm not locked up all the time. Any replies would be helpful, thanks.
Old Nov 9, 2004 | 01:35 PM
User 051420's Avatar
ARB Air Locker, only the best! Do a quick search for locker.
Old Nov 9, 2004 | 01:56 PM
roger's Avatar
Yeah, if you want a selectable locker ARB is probably the way to go. Or you can swap in the entire rear end from an e-locker equipped Taco.
Old Nov 9, 2004 | 03:19 PM
Flygtenstein's Avatar
No, he can't. If he has an open diff'd Taco, he needs either an ARB, RD89, or the whole axle from an e-locked Taco.
I have two ARB's. Buy once, cry once.
Old Nov 9, 2004 | 03:31 PM
Ironmike4x4's Avatar
I thought you could retrofit an e-locker? The link is dead now but there was a section in here that someone had retrofitted one in his 4Runner wasnt there?
Old Nov 9, 2004 | 03:33 PM
Nope. The NON-TRD axle uses an 8.4" ring while the TRD and 4Runner axles use the 8" ring.
Old Nov 9, 2004 | 03:39 PM
Oh ok I wasnt too sure about that, thanks for clearing that up.
Old Nov 9, 2004 | 05:22 PM
CrAshBy's Avatar
thanks alot for the replies, how much do the ARBS usually go for? and do i need a compressor for it?
Old Nov 9, 2004 | 05:25 PM
My ARB RD23 was around $650. The ARB compressor was $200, but there are other options out there for compressors, it all depends on what you want to do with the compressor.
Search "arb locker"
Old Nov 9, 2004 | 05:45 PM
RD23 V-6 8" Toy diffs
RD90 7.5" Toy front diffs
RD89 8.4" Taco/Tundra/T-100 rear diffs
$650 is pretty reasonable. If you look around on PBB, you can snag a deal from a vendor or a used unit.
Old Nov 9, 2004 | 05:48 PM
CrAshBy's Avatar
whats PBB sorry im knew to this
Old Nov 9, 2004 | 06:03 PM
EWAYota's Avatar
http://pirate4x4.com/welcome1.html
RD23 V-6 8" Toy diffs, thats the same for the 4cyl rear too correct?
Old Nov 10, 2004 | 08:02 AM
roger's Avatar
That's what I meant by 'rear end' i.e. not just the diff. Sorry for any confusion!
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
justdifferentials
14
Jun 11, 2017 08:36 PM
zz_denis
Sep 6, 2015 03:43 PM
justdifferentials
Sep 5, 2015 06:52 PM
