T/g 4.70 t-case gears??????
I have an 86 4runner, sas, 35" boggers,stock 4.10 gears. has anyone used trailgears t-case gear set 4.70:1? im thinking about useing that instead of changing the axle gears. im a trairider. i dont do any rock crawling mostly climbing creek banks and such. any suggestions or info is appreciated. thanks
Dozens of times. I use what I sell. It's a pretty straightforward mod if you got tools and can brush your own teeth.
http://www.wabfab.org/Transfer-Cases...-products.html
:wabbit2:
:wabbit2:
x2. the only time the lower low range will help is in low range lol. regear first. it will be much better for your situation. unless your doin alot of low and slow stuff like crawling, you dont need the 4.7's.
exactly..the 4.7 gear set is for LOW RANGE.
if you're still underpowered while in 4LO...then the 4.7's will help.
might i suggest getting a set of 5.29's? or even 4.88's.
x87236483276 for fixing your diffs first, bro.
4.7's will help you crawl, which you clearly stated you don't do.
5.29's sound like your ticket.
a 5.29 with a 35 in tire brings the overall ratio the closest to stock, by fixing the differential gears you will regain all of the drivability that you have lost with a 35.
priest16
15
08-06-2015 07:43 AM
justdifferentials
Just Differentials
07-22-2015 08:26 PM
WTB[PacNorWest]: w56 c manual trans with t-case and drivelin
89hilux1
07-19-2015 01:32 AM
