rear springs for 02 4-runner
I have an 02 4-runner with a Rev-Tec 3" Suspension lift. All springs and shocks are stock. As you may have guessed, my rear is sagging with a medium load. Can I go with the OME HD springs? I know they are made to be installed with OME lifts but will they lift my rear higher or level me out since I already have the 3" lift? Hope this makes sense. Basically, I'm just trying to get the rear up with a sufficient load in the back.
Thanks,
Lou
Thanks,
Lou
1 Post
I'm running OME 890s. They lifted the rear 3.25" over the sagging stock springs. The 890s should only give 2.75" of lift. They handle a load great and aren't too stiff.
OME Info: "I am giving you the approximate lift heights, your exact amount of lift will vary slightly depending on the condition of your current springs. The front heights are respectively: 880=1.25", 881=1.75" & 882=2.25" and the rears are: 906=2.0", 890=2.75" & 891=3.0" . The 882's are not an ARB/ OME recommended fit, but our experience has shown that they work well with some applications. " (info given from 4X4 Connection)
Very cool! Great info! If i'm not using the stock rubber cones should I get the 10mm spacers? Who did you order from and what kind of cost am I looking at? I had another 97 before this one and had bilstein adj coilovers in the front with a 3" spacer and h&r 1" progressive springs in the rear that I got from performance products. I can get those same springs now but they want $199 for them
Flying91
45
04-11-2024 04:39 PM
FS[GreatLakes]: Toyota collection part out
88sasturbotoy
08-11-2015 01:56 AM
cgilley
07-15-2015 03:32 AM
