off roading
off roading
i went off roading today with my buddies and a k5 blazer. i was suprised how little torque my 2nd generation 4 runner had. i got stuck twice in the mud and my friends blazer had to pull me out i was just wondering if you guys were facing the same problem?
Neither the 22re nor the 3.0 have much horsepower or torque, but I don't think that's what is causing you to get stuck in the mud. What kind/size tires do you have versus this Blazer? Once your tread fills up with mud, it's very hard to gain any traction at all.
Your a discrace!
You're supposed to be pulling out the Blazer, not the other way around!! hehe
I used to wheel my '89 4-banger everyday and never got stuck once... I pulled out Rangers and Chevys all the time.... Well maybe twice. heh
How about air pressure in the tires? That's a very big consideration. Unless the Blazer had *very* large tires and yours were stock or bald that shouldn't have happened.
YOU CAN DO IT!!!!!!!!
Last spring we had a mud bog next town over. 4 trucks made it threw, two were toyotas, one with the V6 and the other i believe had a 22RE. Both on 35's.
The other two to make it, a old Jeep Keiser on 44's and a old Ford on 38's or something like that.
The key with mud, good mud tires and momentum. Got to keep the tires spinning, allowing the tires to clean themselves. Dont need to go blasting thru it either, just dont stop.
yeah as the others said, tires are a big thing... also driving technique... 2nd or 3rd gear(if you have a manual) will give you plenty of power to get through the mud. if you are in a high gear sure you will get momentum before you hit the hole but then you will start to "bog down" and it will feel as though the engine has no power at all. Ahh the days of "muddin'"....
... I got sick of cleanin my rig so I stick to the trails and rocks.. it stays dirty, just not muddy... working under a muddy rig sucks.
i have 31's and my friends k5 has 35's and is lifted i had it in 4L but i couldnt get out i turned the wheels backed up did everthing i dunno i was probably doing something wrong so its good to hears its not the torque!
that being said.. mud isn't that fun, find an ORV park you'll have so much more fun on the trails IMO
... technical skill progression of wheelin': mud--->trails--->rocks
Originally Posted by SC4Runner
Your a discrace!
I have done this....Pulled out a Kblazer with dana 60 and 44s with one tire completely off the rim. That was fun. Its great when a 4cly. yanks a gigantic V8 out.
Not to highjack the thread, but im locked fr and rr, running 33" Firestone MTs, 4.88 gears, 4LO, with momentum and still get stuck all the time... I think my problem is the truck doesnt have enough guts to spin the tires fast enough to clean them...
So then thinking lockers, i tried running it on the side with two tires on somewhat more solid ground and still got stuck:
Yep, deep mud and sand are two places where you need horsepower to get enough wheel speed to do any good. Many of the common "MT" tires are really not good in deep, heavy mud. You need a real mud tire like a Super Swamper TSL or Bogger to work there. I know my BFG MTs are only so-so in mud. My old Swampers were a lot better, but I prefer dry ground and rocks to mud.
The goal was to get my truck in something it couldnt get out... so we found the muckiest hole we could, and well the pictures show the rest. It was very thick, soupy mud... and pretty much bottomless.... i found out later a full size chevy locked front and rear with 44's dug it out a little before i got there....
I can see a set of boggers and a V8 in my 4Runner's future :-p
My experience is Toyota's in 3L and 2.4L form are not mud trucks. I've hit mud holes with good momentum in my 85 4Runner running 31" BFG AT's and in 2nd gear 4LO the engine would bog to the point of stalling, even though I hit the hole at 4 grand WOT. I can't imagine how underpowered it'd feel with big mud tires. It could at least spin the tires in 1st gear low range... but even at redline there is nowhere near enough wheel speed to clean the tread, even on a good mud tire. To mud you need to be able to turn big agressive tires FAST... and you need power to do that.
My fullsize Chevy with 33" mud tires and a built 400 makes a cake walk out of similar mud holes. Just stand on the gas, watch mud fly 30' in the air and hold on!
