mini spools
mini spools
Ok so I've got a '88 toyota pickup, has the v6 with a 5 speed. My problem is I am planning on doing a motor swap to wither the 4.3 or a 350 not real sure yet. I also want to lock the rear end after I do it. I am under the assumption that it is a non c-clip rear end which means there should be a mini spool available for it. Does anyone know where I can find one so I can avoid the welded gears. also am I wrong in assuming it's a non c-clip rear end?. Thanks, Craig
I've never heard of a mini spool for a Toyota. But you can get a full spool.
http://www.marlincrawler.com/3rd_pickup.html
It's not a c-clip rear end, the axles slide in and out on their own into the dropout differential. No clips holding it in.
JookUpVandetti
09-17-2015 09:25 PM
priest16
15
08-06-2015 07:43 AM
