Inchworm E-locker harness blowing fuses
Old 01-01-2007, 03:29 PM
ADH8796's Avatar
I had run all the wires for the E-locker switch except for the ground but while grounding the ground wire to the frame the ground wire sparked and blew the fuse. I don't think the ground wire should have sparked or blown the fuse but I can't figure out whats wrong. I replaced the fuse and blew another. So I pluged the wire into a 10 amp fuse and it didn't blow but I didn't get any power either.
Here are the pics of he chart and the fuse box covers I would like your opinion on which fuse to tap into. It suggest the radio fuse but I don't know where that is so I have been taping into the DOME Fuse which is 15A. Thanks!
http://s139.photobucket.com/albums/q...orm%20harness/
Old 01-01-2007, 03:56 PM
rimpainter.com's Avatar
Wait, so you never fixed the wire issue, you just used a different fuse?
Old 01-01-2007, 04:23 PM
ADH8796's Avatar
I have looked at all my wires and according to my wire diagram everything is corret. So I don't know whawt to do from here. I have tried to replace the fuse that burnt and I have also tried to tap into a different fuse. Dose that make since?
Old 01-01-2007, 04:56 PM
Did you color-code all your wiring? I found with my e-locker swap, since I didn't have enough colors of wire, that I ended up losing track of which wire went to what. So, when I went to test the voltage, nothing worked right. I had to re-wire everything.
Old 01-01-2007, 04:59 PM
ADH8796's Avatar
Yes accoring to inchworm wiring diagram I matched up all the wires where they needed to go.
Old 01-02-2007, 06:18 AM
ADH8796's Avatar
Bump for some help I think I may call inchworm later and see what they think.
Old 01-02-2007, 07:16 AM
Robinhood150's Avatar
your link doesn't work
Old 01-02-2007, 07:24 AM
ADH8796's Avatar
Sorry I fixed it.
Old 01-02-2007, 11:48 AM
ADH8796's Avatar
I just talked to the guys at inchworm and they were as helpfull as they could be so tonight I am going to have someone else look at all the wiring and see if they can find a mistake. But I'm still interested to see if anyone else has ideas thanks!
Old 01-04-2007, 06:35 AM
ADH8796's Avatar
Alright I figured it out I didn't wrap all the wires as good as I should have where the new harness wires to the old one. So one of my wires was touching another and causing a short. I took some time and wrapped everything real good and now I have my locker and I love it. Thanks for the help.
MO transplant
04-23-2023 11:58 AM
theking11863
03-19-2016 09:36 PM
izzmee
08-17-2015 10:20 AM
Mrhoadley
08-04-2015 06:08 PM
80Truck
07-24-2015 03:12 PM
Quick Reply: Inchworm E-locker harness blowing fuses
