YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Offroad Tech
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 10-06-2008, 09:04 PM   #1 (permalink)
Stuckyota's Avatar
Unhappy HUB wont completely go free
Hey all, im new to the site and love it so far. I looked around and can't find an article that adresses this exactly. A few that kinda sounded like it might but im not sure. So after it rained tonight, I went out to test the new pro-comps in a LARGE "rain puddle", after some good enjoyment and satisfaction from the new tread, I was going to drag all my newly collected parts of earth, to a car show haha and went to unlock the hubs, and the passenger hub wont quite turn all the way to "Free". Its close, it has happened before, but after rolling the truck forward a few feet, it went all the way with some elbow grease. But now it won't turn all the way to free.
Does this mean its still engaged?
Is it a big deal?
How do I get it to turn all the way?
I read an article on a dude named arron's truck, and he had some cv needles that broke apart and jammed it?
Plz help its my daily driver!
Stuckyota is offline
Sponsored Links
To remove this ad, register today!
Old 10-06-2008, 09:21 PM   #2 (permalink)
slosurfer's Avatar
You'll have to take it apart. I'm guessing too much or not enough grease, both can cause that problem.
__________________
Chris
6th Annual Pismo 4runner Jamboree: Oct. 10-12, 2008
'93 4runner SR5 3.0 Auto 4WD
'07 Tacoma Dcab 4x4 TRD offroad
'89 F250 4x4 w/utility bed
M416 1/4 ton military trailer
"Some people spend an entire lifetime wondering if they made a difference. The Marines don't have that problem."
Ronald Reagan
Semper Fi
SLO 4wheelers
slosurfer is offline
Old 10-06-2008, 09:23 PM   #3 (permalink)
OSU4Runner's Avatar
Send a message via AIM to OSU4Runner
Take it apart...clean it out and regrease it.
__________________
2006 Tacoma SR5 - Stock for now
2000 4Runner Limited
16x8 Pro Comp Steelies wrapped in 285/75R16 Pro Comp M/T'S~RB 2" Body Lift~Goodridge Front and rear brake lines~Rear Locker Mod~Rear Diff Extended~Surco Safari Rack~ Optima Yellow Top~ Trail Gear Sliders~6 100W Hella 500's~ Deckplate Mod w/ True Flow~ISR Mod~~Autometer Volt and Oil Press gauges~Satoshi Grille~Redline Hood Lift~Hayden 1678 Aux Cooler~Safari Snorkel
OSU4Runner is offline
Old 10-06-2008, 10:52 PM   #4 (permalink)
Stuckyota's Avatar
will do, thanks for the input!
Old 10-08-2008, 02:23 PM   #5 (permalink)
Bru
Also something to look at is the spring inside the hub. I have had 2 hubs die on me. Each time it has happened they have broke in the locked position. If you can not turn it, it could be broke.
__________________
Bru
IYAAYAS!!!
Bru is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Wheel bearings replaced but now Manual Hub wont engage 88Yota4runner Newbie Tech Section 7 07-16-2008 06:17 AM
Manual hub stuck in (free) position hmmwv15 86-95 Trucks & 4Runners 6 05-27-2007 08:05 PM
locking hub wont go back to free gilkey Maintenance & Repair Archives 3 10-21-2005 07:39 AM
Help! Got brakes apart but rotor wont seperate from hub/bearing!! gotime242 95.5-2004 Tacomas & 96-2002 4Runners 19 03-26-2005 08:32 AM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
