| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Hawse, or Roller Fairlead with Plasma Rope?
__________________
Traumahawk 2000 Tundra, 2001 4Runner, 1983 Toyota P/U - Bobbed, 4.7 T case, lockers, 33" mtr's, 4-runner v-6 rear end, front wheel spacers, 2" shackle's Ding A Ling Dang My Dang Along Ling Long |
#2 (permalink) |
Hawse fairlead for sure, aluminum or better yet UHMW poly is the best material for the fairlead (same stuff as the rope).
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad Gettin'Off 4WD Club |
#3 (permalink) | |
Quote:
#4 (permalink) |
I was also concerned with the distortion of the end-mounted UHMW fairleads as well. The UHMW fairlead I'll be making will be attached top and bottom with multiple bolts and will also fit inside the winch access hole on my front bumper to prevent this. My main concern w/ aluminum is that my fairlead sticks out in front of the bumper and would be the first thing to make contact with a big rock on the trail. Gouging up the aluminum would leave sharp edges that could damage the rope. If your fairlead location is fairly well protected, then aluminum is probably fine.
I've heard that with roller fairleads, you can have problems with the UHMW rope slipping into the gaps between the rollers, since it is not as stiff as the wire rope.
__________________
#5 (permalink) |
I just picked up a m8000 and the UHMW fairlead and had the same concerns about distorting. When I build my bumper I planned to use some angle iron to support the top and bottom edges.
Scratching the Aluminum fairlead is the reason I went with the plastic one. http://www.sky-manufacturing.com/
__________________
Steve. '93 4Runner V6 Auto 4x4 Robinhood's Lair. || Gettin' Off 4wd Club member Lots for sale:5.29 ARB IFS third member... Click Sierra Club policy: [A reason to close trails] ...Physical soil damage, often readily visible, resulting in: a. Erosion, causing soil loss and damage to stream banks, streams, and fish habitat... Lesson...Stay on the TRAIL! |
#6 (permalink) |
Thanks for the input guys, I think I will try the UHMW Hawse!
__________________
| Tags |
| arb, blue, fair, fairlead, fairleads, hawse, lead, locations, plasma, plastic, roller, rope, uhmw, versus, vs, wire |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Hawse vs. Roller fairlead? | chimmike | Offroad Tech | 14 | 04-29-2007 07:19 AM |
| wanted: hawse fairlead | nc994run | The Classifieds GraveYard | 3 | 11-18-2006 10:14 PM |
| Winch cable and Hawse Fairlead | p1michaud | The Classifieds GraveYard | 5 | 06-09-2006 03:46 AM |
| Hawse or Roller Fairlead? | trx125 | 86-95 Trucks & 4Runners | 2 | 05-27-2006 06:15 PM |
| ARB bumper hawse fairlead mod | Shane | The Fab Shop | 5 | 03-28-2004 10:49 PM |
