Crazy Idea!
Crazy Idea!
I don't think i'd do this but... could you run BFG AT KO 33X10.50 in the front to slove steering clearance probs and a BFG AT KO 33X12.50 in the rear for better traction?
Sure, why not? A friend of mine had a set of Mickey Thompson 35-15.50's in front of his dually and dual 35-11.50's in the rear. Worked just fine. Check manufacturers specs on the tires though, tires of a given listed diameter vary in true diameter. Also, putting a 10.50 and a 12.50 on the same width rim can result in different diameters. Probably need to use a 8" rim in front and a 10" rim in the back.
Originally posted by crawler#976
yes, but what ya gonna do when it's time to rotate'm? Only going from side to side only won't help much for the front tires-
he's gone
7
12-03-2019 07:08 AM
itzmywife's
07-25-2015 04:55 PM
Bflo338
07-21-2015 07:28 AM
Seattle_Sign_Guy
07-12-2015 12:38 PM
