BL Bolt Lengths
BL Bolt Lengths
On my 3rd Gen 4Runner, I ordered the Roger Brown Body Lift blocks, and planned on buying my own grade 8 hardware. Well, I was hoping someone could help me out with the lengths of the factory bolts. Are they all the same lengths, or are some different?
Try asking Roger.
To show you what a good person he is I e-mailed him that I wanted to provide my own stainless steel hardware AND my own lift blocks because someone locally has some UMHW available for me to use on my truck. He gave me the three lengths to use so give it a try.
Disclosure: I did buy a pair of BJ spacers and a short throw shift adaptor block from Roger in December so please don't think I was totally taking advantage of his expertise in this area.
If you look at the bolts that are currently installed on your truck (at least on a 2nd gen) some of them have a LOT of exposed thread so if you are doing a minor lift you may be able to use the existing hardware. If you read Roger's website, it says what the limit is on height of lift if you want to keep the existing harware.
