Ball joint spacers.
Old Dec 17, 2004 | 11:17 AM
az4x4runner's Avatar
Question Ball joint spacers.
I know there are tons of threads on ball joint spacers and how to install them on this forum as well as others. What I want to know though is if those of you with them on your stock IFS run anti-sway bars or not. I haven't had the front sway bar on my 4Runner for probably two years or more now, so I was wondering if anyone thinks it is necessary with the 1.5" ball joint spacers (I probably wouldn't back off on the t-bars so I could gain 1.5" ride height). It doesn't seem like I would need to put the sway bar back on since I wouldn't be letting the t-bars down any.
Thanks,
Bryan
Old Dec 17, 2004 | 12:09 PM
KevyWevy's Avatar
there is no reason that you would have to put the sway bars back on.
Old Dec 17, 2004 | 06:40 PM
Marc P's Avatar
I have my swaybars off and my torsion bars as loose as I could make them, but still be ok on turns without too much roll. I still enjoy the almost 2 inches I gained over stock.
Old Dec 17, 2004 | 11:16 PM
Cool, just wanted to make sure it didn't make the body roll too much worse. I didn't figure it'd be a problem, I hardly notice I have more body roll than other vehicles now anyway since my sway bars have been disconnected for so long.
Nice looking 4runner by the way.
Old Dec 18, 2004 | 08:46 AM
Flygtenstein's Avatar
I got no lift out of the spacers and picked up quite a bit of body roll. My front is pretty darn soft right now.
The wonderful thing about swaybars is you can put them on and take them off easily. If you drive fast and don't like it, then put it on.
Old Dec 18, 2004 | 05:30 PM
Marc P's Avatar
I get some pretty decent flex out of the front now-
Old Dec 22, 2004 | 12:12 PM
PAhydrohead's Avatar
Marc,
Did you have to install longer shocks to get that flex? I've got some BJ spacers on the way from R.B. and a set of Rancho 9000s (stock length) on the truck now. if I'm going to need new shocks, I might as well start looking.
Old Dec 22, 2004 | 12:20 PM
KevyWevy's Avatar
to get the full flex you'll need longer shocks, but if you just don't want the extra flex, they stay with the stock shocks. i went with some procomps in the front i took the extended and compressed messurements from my truck and found that the shocks that they put on their 4" lifts were the perfect size, but that all depends on your truck, so the best thing to do is to buy, measure then look.
Old Dec 22, 2004 | 12:30 PM
Did you mean measure, look then buy?
Did you change out the bumpstops to the low profile ones?
Old Dec 22, 2004 | 01:07 PM
Mikronized's Avatar
so you installed 1.5in spacers and got no lift?? why is that?
Old Dec 22, 2004 | 05:06 PM
KevyWevy's Avatar
hahahahaha oops, yeah, measure look buy. i changed my compression bumpstops to low profile, but with the bj spacers, you're not supposed to use low profiles for the extention bumpstops.
Old Dec 22, 2004 | 06:41 PM
Marc P's Avatar
I used the same procomp shocks as Kevywevy. I also put a new steering stabilizer at the same time. I am using my stock bumpstops, and have removed the swaybar.
Flyght may not have seen any lift because he has the TJM bumper and winch that add quite a bit of weight.
Old Dec 22, 2004 | 09:24 PM
Sweet, even got shock information. Now if only I could actually get some decent shifts where I work so that I can afford this stuff.
Old Dec 23, 2004 | 07:56 AM
Napoleon047's Avatar
im guessing he uncranked his torsion bars because he didnt want any lift, he just wanted the added flex.
Old Jan 14, 2005 | 05:26 PM
Yamaha+Toyota=Fun's Avatar
So you have somthing like this
http://www.truckperformance.com/prod...oductID=992488
Old Jan 14, 2005 | 06:56 PM
KevyWevy's Avatar
yup!!!
kawazx636
Oct 6, 2021 03:03 PM
ladybugRC
458
Aug 21, 2020 10:41 AM
4x4YOTA
Aug 23, 2016 09:08 AM
crash813
Sep 27, 2015 07:15 AM
Odin
Sep 26, 2015 06:56 PM
