1991 toyota pick up 2wd
i have a 1991 toyota pick up .. 2 wheel drive model..
when i bought the truck it has 30-9.50-15 size tires on the front and 235-75-15 on the rear.. the body is almost touching the tires and the front tires are scrubbing when i turn the wheel.. i was wondering on how a 3 to 6 inch body lift would look and if that would do the trick for me.. i also have a grill guard and a winch i want to install on it.. i kinda want the 4 wheel drive look on a 2wd
any help would be really nice thanks
I have 15x30x9.50 front and back, before i got a long travel kit my tires would hit the cab when bottoming out and rub during hard turning in the front even with my torsion bars cranked, maxed out. When i got my long travel kit i just reinforced my stock spindles but did a 1" body lift for tire clearance and have had no problems ever since. With a 3-6" body lift your going to be stretching wires throughout your truck, your frame will be hanging down below your truck and wont get the look your going for. You can also clearance your bumper by cutting some of the metal off the lower part of the bumper where it scrubs, cab side you cant do much
06-01-2021 01:51 PM
Aleeex_u
06-05-2016 06:52 PM
Jnkml
07-06-2015 01:20 PM
