Armor underneath?
Old Aug 28, 2012 | 03:52 PM
RockyMtnToy's Avatar
Armor underneath?
Hey everybody,
I have a 1996 taco, and i'm fairly new to wheelin.
What would you recommend for armor for all the underneath components?
Obviously what lines I drive would be the best protection, but just in case...
Edit: If this isn't the right section to ask this, let me know, it just seemed like the right place to post.
Old Aug 28, 2012 | 04:06 PM
BeMiceElf's Avatar
You could start with BudBuilt.
Old Aug 28, 2012 | 09:31 PM
Ill check them out thanks
Old Aug 29, 2012 | 10:27 AM
highonpottery's Avatar
sounds like you want a transfer case skid plate/crossmember. budbuilt, skid row, all-pro just to name a few. this will not only give better protection since it's a big 'ole chunk of steel plate where you'd most likely hit during a high-center, but will also gain you some belly clearance to avoid hitting in the first place. you can also get a full belly plate system from front to mid, like what budbuilt makes.
if you have an e-locker, get an e-locker guard - try inchworm gear.
don't forget some sliders if you want to be able to open your doors in the event of a boulder (or even a car door) hitting your rocker panel. Trail gear is the cheapest option if you have a welder. Heck, TG even has an armor pack for your rig, just doesn't have a skid plate.
Old Aug 29, 2012 | 10:33 AM
also - if you order something like a skid plate from vendor, see if they have some low-profile magnetic drain plugs to install on your diffs and t-case. you'll thank me later
Old Aug 29, 2012 | 06:00 PM
Thanks for pointing me in the right direction everybody
Old Dec 21, 2012 | 09:10 PM
Bordrforlife's Avatar
skid plates on everything important! plus sliders to protect your cab, very important
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
matmattmatthew
10
Feb 9, 2021 04:15 PM
dzldust
7
Oct 6, 2015 05:39 AM
toyotasaurus
Sep 24, 2015 03:30 PM
irv
Sep 22, 2015 11:51 AM
