| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
speed sensor wire help
__________________
1995 sas 4runner worked on by Cornfed... blew up week later 1993 SAS 4Runner, 4.88s, locked front, TRD e-locker rear with Inchworm kit, 35x12.5 BFG MT's, rock crawling rear bumper, All Pro front tubular bumper with Mile Marker SE12000 winch, Hella 500's, front & rear hitches, sliders, k&n drop in with ARB snorkel, custom duals, Federal Signal siren with whelen red strobes! custom front spring mounts rear susp. added another 2" of susp lift totaling at about 9" |
#2 (permalink) |
No idea about the Tundras but on my 4Runner I found the green/orange wire coming out of the stability control ecu. The sensor on the trans isn't used for the speedo signal. On mine the stability ecu gets signals from the 4 wheel sensors, averages them, and then send a signal down the green/orange wire to the speedo. If you have stability control or traction control yours might be similar.
__________________
2001 4Runner 4.30 ratio 1999 e-locked rear axle and front diff; OME881/N91S front; OME891/N86 rear; Tundra brake swap; 1" 4Crawler body lift; 63" 4Crawler SliderZ; TJM T-15 with Warn M8000 winch and Amsteel blue synthetic line; 265/75R16 Nitto TGs or 255/85R16 Truxs MTs; Cobra 75 WX ST cb; Alinco DR635 VHF/UHF ham radio; ham call sign license plates - VE7 EGC |
#3 (permalink) |
yeah i found out on the tundra the signal is converted at the speedometer so i tapped into the wire behind the instrument cluster...
__________________
| Tags |
| 2002, 2003, 4runner, landcruiser, orange, sensor, sequoia, speed, vehicle, vss, wire, yotatech |
