Rear mounted fuel tank for an FJ80
Hey Guys,(and maybe girls) I'm a toyota newbee. I was out looking for a pickup but saw an FJ80. I was hooked. Looked underneath and saw the potential for a nice HD off-road tinker toy to satisfy my need to modify. Ok, the fact that it was quieter than my cj, and had A/c may have swayed me to the dark side. I'm not getting any younger and creature comforts are becoming more important to me. I'm now installing the drive train for a 2000 Silverado. Now to my Question. I'm trying to find a local source for a rear mounted Fuel tank with sender compatable with my cruiser gauge. I'm running a centered driveline to the rear and have to remove the factory tank to clear it. Any Ideas, sources.
Any demand for the old drive train. or should I dump it. All ran well but underpowered for the weight.
www.man-a-fre.com has a couple different options for you. One option is to install a sub-tank from Australia. These are used tanks from Aussie cruisers. IIRC, they hold just under 15 gal. The other option is to go with a full 2nd tank -- I think these hold somewhere in the neighborhood of 34 gal.
Check here:
http://www.man-a-fre.com/parts_acces...ueltankkit.htm
If you're in So. Cal, they should be fairly close to you.
Good luck.
Check here:
Good luck.
problem solved, no new tank needed
and use the innards from an amc th400. I can then bolt a quadratrac t-case, which is offset like the HF2A and keep the fuel tank in place. This will cost much less than the other options. I thought about a dana 18 t-case, but feeling were mixed about its strength. again, thanks.
jerusry
10-19-2015 05:28 PM
TURBOrunnerNM
07-22-2015 11:01 AM
icentropy
07-09-2015 02:12 PM
skoti89
07-08-2015 12:05 AM
