YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > Early Land Cruisers
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 10-15-2007, 09:53 PM   #1 (permalink)
Need your help with Cooling problem-O
Good Morning, I have a 1989 FJ62 that has me vexed, if you have any clues, please send them my way.
My radiator blew out the bottom seam, so I ordered a new one and decided to change out the thermostat while I was in there. The lower thermostat housing split on me and I had to purchase a new one from the stealer. Provided gaskets were wrong, so I fab'd new ones myself with some handy dandy Mr. Gasket, gasket stuff. Now, when I go to fill the system withwater, and the engine NOT running, water is F L O W I N G from somewhere in the neighborhood of the water pump (the only part I haven't replaced. Now, I understand that the FJ62 water pump is a two piece unit, what could be the cause of the mysterious water leak? I mean, it's a very apparent leak, without the engine running, this is like a rivlet of water, not a steady drip, drip, drip. I am stumped. I also replaces all rubber under the hood to be sure.
Any and all assistance will be rewarded with great karma.
Thanx, please reply to rfc2307@gmail.com
rfc2307 is offline
Sponsored Links
To remove this ad, register today!
Old 11-11-2007, 08:04 PM   #2 (permalink)
Luvmeye22re's Avatar
If it's anything like my FJ60 was, there is a tiny little hose between the bypass hardline attached to where the water pump mounts and the water pump itself. The hose is about 3 inches long. I had one blow up and you can't see it at all without removing some crap above it.
__________________
86 Runner with rebuilt 22re and 5 speed swap
Luvmeye22re is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Strange problem - 3VZE dies, then runs OK after cooling off tc 86-95 Trucks & 4Runners 34 07-08-2007 11:13 AM
condenser cooling rugerm44 95.5-2004 Tacomas & 96-2002 4Runners 0 07-06-2006 04:56 PM
weird cooling problem elkdog 86-95 Trucks & 4Runners 4 03-26-2006 03:29 AM
cooling problem or am I just being paranoid sampson 95.5-2004 Tacomas & 96-2002 4Runners 9 01-01-2005 02:38 PM
PC cooling Corey Computer Talk 25 07-24-2004 03:53 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
