FJ80 axle questions - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > Early Land Cruisers
Welcome to Yotatech!
Welcome to Yotatech,
Old 07-05-2009, 02:52 PM   #1 (permalink)
FJ80 axle questions
I'm wanting to learn everything i can about FJ80 Axles. I'm considering buying some for my Jeep XJ but don't know much about them. What are the strengths, weeknesses in them? Any certain years/types i should stay away from?
__________________
www.4x4grace.com
99ncxj is offline
Old 07-05-2009, 07:02 PM   #2 (permalink)
BAMF_CT2004's Avatar
ih8mud.com
__________________
Let me tell you what Melba Toast is packin' right here, all right. We got 4:11 Positrac outback, 750 double pumper, Edelbrock intake, bored over 30, 11 to 1 pop-up pistons, turbo-jet 390 horsepower. We're talkin' some muscle.
Quote:
Originally Posted by GreenFlames View Post
just because you called me a web wheeler what ever that means.
BAMF_CT2004 is offline
Old 07-05-2009, 07:44 PM   #3 (permalink)
Quote:
Originally Posted by BAMF_CT2004 View Post
ih8mud.com
Yea, thanks. I'm searching over there too. Just thought someone here might have some input on them.
__________________
www.4x4grace.com
99ncxj is offline
Old 07-27-2009, 05:43 PM   #4 (permalink)
Go with the portaled Volvo axles....
GarnerFJ40 is offline
Old 07-27-2009, 07:13 PM   #5 (permalink)
AxleIke's Avatar
What exactly did you want to know?
They are strong. 5" birf instead of the 3.5 in mini trucks. If you find the right years, the rears are Full Float with disk brakes. Should handle 37" tires stock just fine. To be safe, upgrade to longfields in front, and poly performance chromo shafts in the rear.
Both front and rear came with electric locking differentials on some models. Both front and rear have offset diffs to the passenger side. Meaning, if you have a center drop t-case, and you drive on the road, you are going to get driveline vibrations pretty bad if you use the rear axle. I can't remember what drop the XJ's are in the front, but I thought they were passenger.
63" WMS to WMS in the front, 62.5 in the rear, IIRC.
Front is a high pinion (30% stronger) 8" diff, rear is an 8.875" regular diff. The rear is really strong.
Front high steer can be done with OTT arms (require machining at OTT= have to send your knuckles out) and leaf springs. Slee high steer requires links as leafs will not fit. Figure 6-700 for the steering.
More can be found on IH8MUD, and Pirate.
__________________
1987 Mutant 4runner|Slightly Modified|Lacking general build direction
-Lifts and Tires look cool at the Mall, Lockers and Gears look cool on the trail.
-Internet Nice Guy
AxleIke is offline
Old 08-13-2009, 08:57 PM   #6 (permalink)
great axles to bad jeep doesnt use them any more. I do have extensive info on the type of lube to use in the enclosed knuckle if interested I will elaborate further
Transmission Frank is offline
Old 08-13-2009, 09:32 PM   #7 (permalink)
AxleIke's Avatar
Jeep used FJ80 axles? Find that pretty hard to believe.
__________________
-Internet Nice Guy
AxleIke is offline
Old 08-14-2009, 11:09 AM   #8 (permalink)
enclosed knuckle differential
the enclosed knuckle diff was used by Jeep, International,GMC, Ford, Chevy,Dodge, The design was then sold to Toyota all built by Dana corp the replication by Toyota is so close parts are interchangable. These differentials are nothing new they been around for 70 years.
Old 08-14-2009, 09:27 PM   #9 (permalink)
AxleIke's Avatar
Cool!
I'm always eager to learn new things. For my own amusement and piqued curiosity, would you mind sending me a few links so I can learn more?
Thanks!
__________________
-Internet Nice Guy
AxleIke is offline
Old 08-15-2009, 09:08 AM   #10 (permalink)
more info on enclosed knuckles
Axleike, send your e-mail adress and I will forward scans of shop manuals and a flyer on the proper lube. I am not computer savy enough to post the info because evidently it needs to converted to text to post on this here website.
check out militaryvehicles@krause.com a fellow by the name of Steve Turchet wrote an article on this subject I have e-mailed him my info also there are postings on IH8mudd in 60 wagons under steering knuckle lubracant that are very enlightening on this subject granted it has a negative vibe but I am trying to tell guys something they dont want to here. thanks Frank
Tags
80, 91, arms, axle, axles, codes, cruiser, fj, fj80, high, jeep, land, pinion, steer, toyota
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2009 InternetBrands, Inc.
