| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
78 FJ40 starts but will not stay running
#2 (permalink) |
Location: I live in Red Bluff ca. Right by the Sacramento river
I dont know about fj40s, but I do know about old engines. At first I would say fuel filter, but you say you put a new pump in, so I assume you also did the filter. I would then say it just needed to be ran, because it was sitting, But you say it didnt sit very long. Is it low on gas? Maybe gas went bad in tank? Did you smell gas? Try running some carb cleaner through it. It sounds like something with carb, you say it runs if you block the choke? Maybe its time to rebuild that carb?
#3 (permalink) |
I guess I will try some carb cleaner next.
#4 (permalink) |
While this site is an excellent source of technical information on toyotas, Check this also, you may get a quicker response.
http://forum.ih8mud.com/ It does sound like a carb problem though.. Idle screw maybe? Carb could be gummed up. Good luck
__________________
Duncan -------------------------------------------------- Current: 95 4X4 SR5 V6, Yakima tracks/rack installed. Aisin hubs. Sonoran Steel IFS Truss. Cobra CB(finally!) Desired: 66 FJ45 shorty EX's: 89 4X4 V6 Downey'd 72 FJ40 W 350/SM465 powertrax, "Billy" |
#5 (permalink) |
I've had this happen once before and I thought I'd never figure it out. The solution was the weirdest thing so if you're grasping at straws, here's one to try.
I had a big block Ford that would run just fine in the summer, but when it got colder it would run properly for about 5 - 7 minutes and then die out. Choke was set properly and I was about to drive the dang thing down a boat ramp but I finally figured it out. The thermostat in the cooling system was stuck open. Apparently the engine would get to this weird point where it would be warm enough to open the choke but not warm enough to run without the choke. So it would effectively kill itself after becoming partially warm. So if you run out of options, that's one to try. - Steve
__________________
Steve 1995 4Runner - V6 - 5 Speed Rear ARB, Manual Hubs, Front TruTrac, Marlin Transmission, ARB Front & Sonoran Steel Rear bumpers that have saved my life!! |
#6 (permalink) |
check for power to the fuel cut solenoid, the only wires on the carb. You may have to manually ground it. Have a friend turn the key on and off, you should hear it click.
#7 (permalink) |
Yup, fuel solenoid on the back side of the carb, classic symptom of running only with the choke on. If there is power to it with the key on then you will need to replace it. Mine cut out intermittently for while and then worked after that.
__________________
77 FJ40 36 TSLs, 45 springs in rear, 8274, ARB rear, TBI 2F 97 4 Runner Ltd TLCA# 9203 |
#8 (permalink) |
try running it with out it hooked up. when we put a 20r from a 80 into a 82 it wouldnt run with it hooked up. my dads 20r in his 80 would run with it hooked up and not run without it but for some reason mine would run without it hooked up but not with it hooked up
__________________
86 toyota sr5 with a 1980 20r*sold* 97 tacoma with 2.7 n 5sp-pos that hasnt run in 5months, new crank, main n rod bearing, a few new gaskets 2008 silver honda 600rr |
| Tags |
| 2f, adjustment, carburetor, choke, dies, engine, fj40, idle, ignition, manual, points, running, set, starts, stay, truck |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 96 Tacoma won't stay running | Mike Hagstrom | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 01-09-2009 08:13 AM |
| Engine won't stay running | 89truck | 86-95 Trucks & 4Runners | 30 | 04-07-2007 06:08 AM |
| Doesn't Stay running??? | 943kgt | 86-95 Trucks & 4Runners | 7 | 02-04-2007 04:33 PM |
| 91 4Runner 22RE Starts but wont stay running. | AstroVannin | 86-95 Trucks & 4Runners | 2 | 12-05-2005 07:30 PM |
| 91 4Runner 22RE Starts but wont stay running. PLEASE HELP! | AstroVannin | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 11-27-2005 04:22 PM |
