Vendors Build-Ups (Build-Up Section) Vendors can showcase customer builds here
toyotafiberglass - Davids 4Runner
Old Aug 9, 2011 | 05:26 PM
slacker's Avatar
well he's back ..
a while back , we did some front fenders for him .. and he loved them . We we're talking about My Trekker and the power of his 22re in his Truck ..
so .. 5VZ is now going in ..
Truck is not actually comming in for a couple of weeks , but I wanted to get going on the mods to the engine .
found a good used "kit" with 120 Kelometers on it
started with the clutch ..
NEW complete kit
OLD
and NEW
also .. did the timing belt , water pump , tensioner and Idlers
EDIT : we have the timing belt kits and clutches now IN stock
Old Aug 9, 2011 | 05:27 PM
slacker's Avatar
and now with the oil pan , dipstick and all complete ..
next is the crossover
started cutting it into pieces ..
Old Aug 11, 2011 | 05:33 PM
slacker's Avatar
and crossover is done ..
Old Aug 16, 2011 | 05:09 PM
slacker's Avatar
so continued with the "prep" with Davids parts ..
because the 5VZ requires extra height , we "opt" for a hood scoop instead of a body lift . This is a http://www.toyotafiberglass.com exclusive part , and as well fits the 5vz supercharged "cut out " necessary to fit .
here's how we install it ..
First the scoop has the studs imbedded , so a template is necessary .. a sheet of "art" paper from your local office supply store will sufice ..
Be sure to mark it .. so you know which end is up
now with your "template" .. you can measure , and mark your install
there are a few different positions you can set this at , so .. this one is where we want it .. With that in mind .. time to drill
Take your time on this .. the metal hood skin is thin , and will dent really easily .
depending on your location .. you will have to "open" up holes on the structural braces undernieth ..
and to open it up for a "functual vent" .. we suggest cutting between the supports .. will show this on a latter post .
install , and tighten bolts ..
Old Aug 16, 2011 | 06:22 PM
87 Deathtrap's Avatar
Subscribed- You do some amazing work Slacker!
Old Aug 20, 2011 | 05:30 PM
slacker's Avatar
thanks .. runner in on monday
Old Aug 23, 2011 | 02:36 PM
riderofthegnar's Avatar
Subscribed!!!
Old Aug 23, 2011 | 03:20 PM
slacker's Avatar
so David got his truck to us mid morning , and we went right to work
and just about ready to pull
David .. enjoy the pics , and such .. be like your right there helpin'
Old Aug 23, 2011 | 05:33 PM
B-yodaful's Avatar
sub;d
Old Aug 24, 2011 | 04:18 PM
slacker's Avatar
so out with the old !!
kicked it outside , and got it all clean
and got the old motor mounts cut off
New Tranny prepped , and new T/O bearing
and back in place .. well sorta !!
Old Aug 25, 2011 | 03:32 PM
slacker's Avatar
time for a "test fit"
getting everything test fit .. including the New tranny
Old Aug 25, 2011 | 04:25 PM
LOVE IT!!
Old Aug 25, 2011 | 05:01 PM
vital22re's Avatar
totally a bro
I want that hood scoop. Its easy to install and looks really good.
Old Aug 25, 2011 | 06:50 PM
Lukifer's Avatar
what are the plans for the 22re?
Old Aug 26, 2011 | 04:11 PM
slacker's Avatar
it's for sale ..
shipping to you would be a killer though
Old Aug 26, 2011 | 04:20 PM
slacker's Avatar
send me an email .. lets get the "process" started
there is a "line up " so there is a wait
Old Aug 26, 2011 | 04:21 PM
slacker's Avatar
so , out comes the engine again ..
and weld the engine mounts and zinced and painted
also got all the rear heater plumbing all done and re installed the engine
and some accessories
also started the trany crossmember
Old Aug 30, 2011 | 04:41 PM
slacker's Avatar
so continuing on .. started wiring ..
Old Aug 31, 2011 | 11:52 AM
MSR's Avatar
MSR
how do you repair one of those when a stud pulls out of the epoxy ???
Old Aug 31, 2011 | 03:49 PM
slacker's Avatar
short strand "kitty hair"
