Vendors Build-Ups (Build-Up Section) Vendors can showcase customer builds here
Toyota FiberGlass: 1st 1983 Trekker Build-Up Thread
Old 09-07-2007, 05:23 PM
  #81
slacker's Avatar
tks . I need a beer
Old 09-08-2007, 03:21 PM
  #82
yotasavg's Avatar
that's looking real good!
Old 09-09-2007, 07:10 AM
  #83
slacker's Avatar
Thanks guys ..
it's getting close to completion , well as far as I'm taking it anyway ! .. now I can start the grinding and final body prep .
Old 09-09-2007, 09:52 AM
  #84
HAVOC's Avatar
Looks like you've been busy.
Guess that means no floorpans for the first gens, huh?
Old 09-09-2007, 03:26 PM
  #85
slacker's Avatar
no ... NOT a Chance ... not yet anyway
There is NO way I can produce them and bring them to market for a price I feel comfortable selling at .
Old 09-10-2007, 06:12 AM
  #86
slacker's Avatar
no .. I wouldnt recommend it .. It would work for only a short while , but would soon delaminate . Metal and fiberglass expand and contract at different rates . you'd be better off , in my opinion .... taking a piece of metal , banging it into shape , and then using a "panel bonder" epoxy , to glue it to the floor ... like the *3M stuff I use , If it is done correctly , it will NEVER come apart , 3m guarentees it .
Old 09-10-2007, 04:44 PM
  #87
slacker's Avatar
no worries bud ... I'm glad to share .
I was looking at my trekker the other day .. and I need floors 2 ... I think I will be building , and welding in pans though , just cuz I can
Old 09-29-2007, 04:43 PM
  #88
slacker's Avatar
so , back on it ... more work on the topper/canopy .. topside .. it's comming ..
Old 10-01-2007, 03:25 PM
  #89
slacker's Avatar
soon .. boy .... soon ..
Old 10-06-2007, 03:22 PM
  #90
slacker's Avatar
so new side windows are ordered , and here ..
I chose a basic canopy window/slider option , as it was the most economical choice .. oh and there 30% tint . look great , I think .
I have to revamp the whole canopy side for the glass to fit , but if ever a replacement is necessary , it will be avaliable anywhere .
Old 10-09-2007, 03:50 PM
  #91
slacker's Avatar
holy cow .... I'm thinking I only want to do this project once .
what alot of work .
anyway , heres the top .. still working on body lines , but pretty good now .
also cutting/filling the window openings ..
these are completly different windows .. not just a bolt in .
and the ROUGH .. ROUGH window fit
Old 10-10-2007, 03:50 PM
  #92
slacker's Avatar
thanks .. these are going to be nice . I think mine I might just do like this .
dude .. my tape is in inches.
Old 10-11-2007, 06:48 AM
  #93
slacker's Avatar
Originally Posted by ocdropzone
Thought the US was the only one still not using the metric system
you are .. just my tape is in inches ..
im not sure if that truck is a Trekker or not , other then the roof line , it looks like it , but I dont think it is .
Old 10-20-2007, 04:47 PM
  #94
slacker's Avatar
so Progress
pulled the plastic cover off because it was all cracked and missing pieces where it is riveted onto the door ..
"hemed and hawed" about what I was going to do .. I was going to make a mould , and make a completly new one .. but to much time and money involved there , so I decided to repair the holes , and send it off to line-x as well .. it'll work out great . and match the rest of the rig .
hatch cover repaired
and sanded and ready for line-x
rear hatch is now completly apart , and ready for some line-X
no luck in finding rear hatch hinges , so I thought I would try to fix these ones . there siezed solid. I had them soaking for about 2 weeks .. each day , taking them out , and lightly "tapping" with punch and hammer .
and finally , they loosened up , and I was able to take them apart .
so all cleaned up , and neversiezed .. and now work great .
Old 10-24-2007, 08:35 AM
  #95
idayota's Avatar
here's a few more pics of the build up on that greenland ice trekker...
...end hijack
Old 10-24-2007, 11:22 AM
  #96
idayota's Avatar
i was asked if i knew anything else about the icelandic trekker (or hilux as the case actually is)...here is a link to the page that has a little info on it.
http://www.brian894x4.com/Hiluxgeneration1.html
Old 10-24-2007, 03:59 PM
  #97
slacker's Avatar
wow .. what a build .
Old 10-30-2007, 04:37 PM
  #98
slacker's Avatar
so a wee bit to post ...
rear section has now been removed again .. time to start working on that .
Originally , the back half sits on a "winnabego" frame , that mounts to the Toyota frame . Bushings were toast , and not worthy of the new set-up .. got me to thinkin'
The Original mounts , I dont think were sufichant , because of all of the "leaks" I hear about , so I thought a softer compound mount would work better with the flexing , and handle a better "sway" of the back 1/2 . So I ended up purchacing some NEW "special" mounts , and some steel to make a new frame .
got it all "tacked up " under the body , so now time to weld it all up .
boxing the ends .
another "goofy" part of the Trekkers is the rear lamps .. They have these silly metal " u " brackets that hold the lamps in place .. you have to drill a hole in your lamps , and mount them to the brackets ??? dumb .....
so took the pockets from the 79-83 beds I build , and glassed them into the Trekker
Very rough right now .. but at least they will be easy to install , and RE & RE .
Old 10-30-2007, 04:38 PM
  #99
slacker's Avatar
and some pics from the owner ..
painted/finished in Line-X
Old 10-30-2007, 04:45 PM
  #100
TurnerR's Avatar
SWEET!!! i'm lovin the blue line-x. looks sic
Quick Reply: Toyota FiberGlass: 1st 1983 Trekker Build-Up Thread
