mmml4's 1999 4Runner Rebuild/Build-Up Thread
Old Jun 14, 2010 | 08:21 AM
mmml4's Avatar
Started with this.
1999 4Runner, 2wd, 3.4 v6, auto. Killed in head-on collision.
Rebuild/build specs:
Replace frame, damaged body panels, damaged engine compartment components.
Front:
SAS with 80 series Land Cruiser axle and coils
3 link with panhard
Ballistic Fab adjustable coil buckets
IFS steering box
Rear:
3 link with panhard
Engine:
3.4 liter 5VZ-FE
Transmission:
80 series Land Cruiser A343F & transfer case running Slee Offroad part time 4 wheel drive kit and manual hubs
Tiptronic type manual transmission shift control
and a whole bunch of other stuff I haven't figured out yet
Old Jun 14, 2010 | 08:33 AM
mmml4's Avatar
Swapping in the new frame.
It started out on leafs but I could'nt find a good steering solution.
Old Jun 14, 2010 | 05:40 PM
mmml4's Avatar
Fitting the new wheel well and core support.
Old Jun 14, 2010 | 05:43 PM
mmml4's Avatar
After seam sealer, primer and paint. I searched and searched but could not find a really good match on the engine compartment paint.
Old Jun 14, 2010 | 05:48 PM
mmml4's Avatar
Your basic frame plating, instead of plugging all the factory holes or plating over them I just cut mine to match so the space between the frame and the plate would be sealed.
Old Jun 14, 2010 | 05:50 PM
mmml4's Avatar
IFS steering box, frame is sleeved with 3/8" stainless pipe.
Old Jun 14, 2010 | 05:53 PM
mmml4's Avatar
Coil buckets tacked in place.
Old Jun 14, 2010 | 10:38 PM
space-junk's Avatar
sooo, when i first saw this earlier today, i thoght it looked waaay too sketchy...
but, just saw it, and i think you do some excellent work... looks great!
Old Jun 15, 2010 | 07:14 AM
mmml4's Avatar
Thanks space-junk, it was very sketchy at first but it has come a long way over the past 2 1/2 years. This is my first build and it has been a huge learning curve.
Old Jun 15, 2010 | 09:53 AM
sweet trav's Avatar
nice work...that's an extensive project!
Old Jun 15, 2010 | 10:24 AM
xskydivingdudex's Avatar
looks good so far... i saw a 4runner for cheap like that but i dont have the skills to pull off wat ur doing.
Old Jun 15, 2010 | 03:07 PM
mmml4's Avatar
My first attempt at building links.
Lower links:
I used 1-1/4" Johnny Joints (18mm thru hole) at the frame, custom sleeves with cruiser bushings (18mm thru hole) at the axle, 1-1/4" ladder bar adjuster for fine tuning and a custom square insert 6" long drilled and tapped 1-1/4" left hand thread 4" deep. Tubing is 2x2x1/4" wall.
Old Jun 15, 2010 | 03:11 PM
mmml4's Avatar
Lower links and frame mounts, not finished with the frame mounts.
Old Jun 15, 2010 | 03:16 PM
mmml4's Avatar
Coil spring stuff.
Old Jun 21, 2010 | 05:25 PM
mmml4's Avatar
Got the engine back in and found the DS engine mount is bent about an inch.
Old Jun 21, 2010 | 05:30 PM
mmml4's Avatar
Upper link:
I used 1-1/4" Johnny Joints (18mm thru hole) at the frame, custom sleeves with a cruiser bushing (18mm thru hole) at the axle, Ballistic Fab 1-1/4-12 righthand chromoly insert.
Tubing is 1-3/4" OD x .120" wall DOM.
Old Jun 21, 2010 | 05:32 PM
mmml4's Avatar
Picked this up and now I got a rear to match my front .
97 Land Cruiser
70,000 miles
full floater
disk brakes
9 1/2" ring gear
63 1/2" wms to wms
Old Jun 21, 2010 | 05:39 PM
mmml4's Avatar
Well I got my upper link tacked in place. I ended up with about 5" of separation at the frame and about 6" at the axle. My next step will be to fit the panhard.
Reusing the Cruiser coil perch.
Old Jun 21, 2010 | 05:44 PM
mmml4's Avatar
Here are a few flex pics. Looks like I got lucky, no interference or binding.
Old Jun 21, 2010 | 05:47 PM
mmml4's Avatar
Here is how it sits now, still got a long way to go.
