Addicted Offroad's 2000 4Runner Build-Up Thread "Intervention"
Old 09-30-2011, 12:17 PM
  #481
ScottyC's Avatar
Originally Posted by paynemw
when i got my rear bumper it had a spring loaded pin which came loose a few times wheeling, and the whole swing out wiggled and shook a bunch. later I had PerkinsPerformance fix up the bumper... he went with a huge bolt(with handle on top) to secure the opening side of the swing out, less play in the swing out arm and it holds the weight better...
I already have both in the works.
Old 10-01-2011, 02:09 PM
  #482
ScottyC's Avatar
Getting close. A few more things to do before its pulled, welded, and painted.
1st pic shows the 1" diameter bolt that will eventually be a twist in T handle. Its sleeved with 1.5 x .250 wall DOM through the swing arm, and lower portion of the bumper.
Old 10-04-2011, 01:37 PM
  #483
ScottyC's Avatar
Tire carrier is done.
Old 10-04-2011, 06:53 PM
  #484
fightman80's Avatar
Smile
That looks really good man! I wish I had welding skills like that, when I built my tire carrier!
Old 10-14-2011, 01:04 PM
  #485
ScottyC's Avatar
So, my 00' 4runner is getting loaded up for a 600mi trip to meet its new owner tomorrow. I leave at 5am tomorrow to go get this:
So, I am sure that I will want to wheel it first thing on Monday morning. So, mini-me, may see some dirt too as well as the "back up" rig. I'll hopefully get some pics up then of both in action finally.
Old 10-15-2011, 03:29 PM
  #486
Fossilized
Staff
dropzone's Avatar
Looks like a trade was worked out.
Does the new toy have heat for winter wheeling
Old 10-15-2011, 04:03 PM
  #487
ScottyC's Avatar
Yes. Picked up the buggy in West Wendover an hour ago. Driving back to CO now.
Old 10-15-2011, 04:45 PM
  #488
2DoorJoRunner's Avatar
Congrats man, looks like this will work out well. Is the buggy yota related at all? And do you think you will add anything to it to give it your personal touch?
Old 10-16-2011, 07:16 AM
  #489
ScottyC's Avatar
Well, the deal is done. 4runner is somewhere in the bay area now. Buggy is sitting out front. I left at 5am yesterday and got home at 5:25am this morning. I stopped in Wyoming somewhere and slept for 2.5hrs last night, but drove 1300 miles yesterday. I'm wiped.
Old 10-18-2011, 06:09 AM
  #490
ScottyC's Avatar
I got home at 5:25am after a 24 hour drive (1300 miles), Slept for three hours, woke up at 8:30am, and started working on getting the panels pulled/swapped and basically just left it on the trailer and went wheeling.
John, Ben, and myself went to do a shake down run. Hunter rode shot gun with me in it. We got to the trailhead at around 1pm.
Hunter and I
BigJohn seemed pretty happy.
http://www.jeepaholics.com/support/F...yflats-104.JPG
Ben getting some seat time
We got it into the shop today and stripped the rest of the wrap and cleaned up the panels, and added our own stickers to it.
Old 10-18-2011, 08:50 AM
  #491
malteserunner's Avatar
Cool buggy, Scotty! Looks like you had a great time with it. What does it have for a drivetrain? Looks like it's built very well.
Old 10-18-2011, 09:22 AM
  #492
ScottyC's Avatar
Dynatrac Axles front & Rear both D60
Detroit locker front/ARB rear with Powertank JetPak 3 mechanical actuation system and comes with spare jetpak tank.
Baja Roof Rack (for trail riding and camping gear/beer/etc)
New gauge cluster/dash panel with RPM, Oil Press, Coolant Temp, Fuel Press, Volts, etc
Mastercraft Seats and 5pt Simpson harnesses
Fire Extinguisher
5.0L Mustang Engine BRAND NEW REBUILD with all the best shizzle
Trick Flow Intake/hydraulic lifters/180 cam/brodix heads/custom exhaust manifold
347 Stroker putting out 350-375HP at crank
Chassis dyno'd 242HP with 42" Kevlar MTRs on it
Atlas II 4.3 t-case with cable shifters
C6 Transmission
ArtCarr shifter
Quick disco steering wheel with full hydro front steering
300M axle shafts front
Black Magic axle shafts rear (touted as even better than 300M)
CTM Joints
Drive Flanges front and rear
16g fueltank with remote fill
chromoly chassis all tig welded
R/L Rear cutting brake
catch cans on all fluid breathers so if you roll it, you just roll it back over and start it
Fuel Shut Off
Two Main Power Switches
Dual Optima Yellow Top Batteries
Tranny cooler fan and radiator
Warn 9500ti Winch with in-cab actuation
Rear 3000lb suck-down winch with in-cab actuation
12Volt Guy Switch Panel
Extra skins for sides
Bead-rolled roof
Regulation firewall
exhaust has muffler for reduced noise
brand new rear driveline by South Bay Drivelines
2.5" Sway-Away Air Shocks professionally built by Swat-Away specifically for competition rock crawling...difficult to unload on steep inclines and very smooth actuation
4" Sway-Away bumps in front
2" Sway-Away bumps in rear
Rear axle trussed
4-link front and rear suspension with adjustable mounting to change your antisquat
Anti-roll bar with adjustable linkage on rear axle
Adjustable seat mounts...i have them all the way back because I am tall.
Front axle has F450 dual piston calipers...rear has single piston
front and rear separate master cylinders at 7/8" diameter from Wilwood
2.5-3 turns clock to clock on steering.
Vehicle can do front and rear digs, cut left and right.
synthetic winch rope
Old 10-19-2011, 06:39 AM
  #493
Fossilized
Staff
dropzone's Avatar
At least put a cruiser grill on it
Old 10-19-2011, 07:41 PM
  #494
I am with ocdropzone ALL THE WAY on this!!!!
Old 02-13-2012, 12:45 PM
  #495
BeastlyLemons's Avatar
Do you have any videos? i need to see it in action
Old 10-23-2016, 07:47 PM
  #496
Reluctanse's Avatar
Originally Posted by ScottyC
Here is some more hard core tech for you guys....................
So, I need a 3rd row seat pretty soon in the 4runner. I figured that I would look into Jeep seats. So, I ended up ordering a Jeep YJ rear seat from bestop. Its a fold and tumble seat that includes the brackets for install it. Drill six holes, and bolt it in. Works like a champ.
Installed:
FWIW, I got the seat from JCwhitney with a 20% off coupon off the internet and Free Shipping. $248 shipped to my shop.
I realize this post is old news, but I'm wondering if it's possible you still have these pics and could repost them? I'm exploring options to add more seating to the 4runner and your post came up. If not, no biggie, just curious- thanks!
06-01-2021 01:51 PM
icentropy
09-16-2020 02:47 PM
mskalmus
05-28-2017 07:51 AM
Avenged
07-09-2015 07:55 AM
Jnkml
07-06-2015 01:20 PM
Quick Reply: Addicted Offroad's 2000 4Runner Build-Up Thread "Intervention"
